-   -   Seems Like This Would Be Simple!!!??? (http://forums.pelicanparts.com/porsche-911-technical-forum/179116-seems-like-would-simple.html)
Craig Roche 08-23-2004 06:51 PM
Seems Like This Would Be Simple!!!??? Solution Found!!
I've been completely redoing my front suspension. When I removed my Bilstein front shock inserts I tossed the roll pin that locks the insert to the strut housing thinking I would replace them. Well, as it turns out it's not that simple!! Pelican doesn't even show a part so I guess Porsche doesn't show a part and I've driven all over town and made a dozen calls trying to find a simple roll pin!!!! Turns out it's not that simple because it's 7mm diameter and that's not so easy to find. I guess when you buy new inserts they come with new pins. I had mine rebuilt and they did not come with pins. I had ordered what I thought was the pin through Pelican but it was not it!!
Has anyone else run into this and what did you do?? Help me please!!!!
chrisp 08-23-2004 07:20 PM
I recall several pelicanites saying over the years that they are usually locally available. John Walker said this as well I believe. Perhaps what everyone uses is something that is close enough. I have never looed in the PP catalog itself but I thought they were there.
Craig Roche 08-23-2004 07:30 PM
chrisp,
Thanks for the reply! I've searched PP catalog till I was silly and pretty sure it's not there. I called Pelican today and they couldn't help me (which I thought was odd) I've searched around and 6mm and 8mm are available but not 7mm. Not sure what to do but I'll try Bilstein tomorrow. It's maddening! It's just a roll pin!!
niner11 08-23-2004 07:43 PM
Craig, I just looked for roll pins at McMaster Carr and they have everything Known to man but 7mm. If you make the conversion they may have a standard one that you can use.
Randy Webb 08-23-2004 09:40 PM
Most large harware stores have roll pins. Whether there is anything special about these is a VERY important question tho. You don't want to put something weak in there. Be sure the stock ones are not hardened or special steel, etc. Have you tried a local dealer or Stoddard's?
Craig Roche 08-25-2004 07:20 AM
For future reference here is the solution to the 7mm roll pin.
I searched everywhere with no luck - Pelican, Stoddard, Parts Heaven, local auto parts, local hardware suppliers and the World Wide Web. With a previous post on this board I found and called Jack French at Bilstein and he knew the part number off the top of his head and I ordered from Bilstein 1.50 each. Here's the info:
Bilstein America - 1-800-537-1085 ask for Dan ext. 5912 or sales.
Roll pin 7mm x 45mm is part number 526370
Here's a few key words: Front strut roll pin, shock insert roll pin, tension pin, Bilstein shock insert roll pin.
Hope this helps someone in the future and thanks guys for the help!!!!
chrisp 08-25-2004 08:41 AM
craig, you are the man. Posting this info for future reference is awesome. Thanks for giving back to the board.
john walker's workshop 08-25-2004 08:48 AM
i have a few.
Randy Webb 08-25-2004 12:26 PM
You guys just wait a while -- pretty soon we will be scrabbling for parts nearly as badly as the 356 guys do now....
