Replacing steering rack gaiters
I'm afraid as I'm doing some work on the car I have yet more questions...
I'm about to replace my steering rack gaiters as they are showing signs of perishing. I have new track rod ends to fit as well. The PO fitted a turbo tie rod conversion. Can anyone give me any tips for steering rack gaiter replacement? I'm trying to avoid removing the rack from the car, so I just wondered if the collective can offer some advice re techniques to ease the new gaiters on. Thanks in advance. |
well, i got really p*ssed with the std retaining springs.....
so i opted for long zip ties, much, much easier to install. i don't known how you get those springs on. |
Oh, part of my parts order is replacement OE springs. They are surprisingly expensive!
good luck with those:D
if the rack was out then fine, but working in a confined space.....:( |
Two thin screwdrivers help hook and roll the spring on. Once you get it about half way you can carefully roll the boot 90-180 degrees and finish the job.
John |
Damn :(
Thanks for the advice John. Wonder how the pros do this type of job? Tools? I suppose a sort of bradawl with an angle on the end to hook under the gaiter might work - but I'd have to be careful that I don't tear the gaiter. How much more work is it to get the rack out? |
not alot apparently. some say 1/2 hour.
i have to get mine out soon because one of the seals has gone, so ill let you know! |
I did one Sunday since one of my boots had split. I few good wacks on the tie rod end and then you can carefully push the boot over the end. I used a lift which made it easier, but it couldn't have taken 3 minutes. Yoiu have to use two tools or it will slip off.
John |
