Check Out My $2.00 Dead Pedal
I just couldn't see paying that much for a good quality dead pedal, so I decided to make one myself. What do you think? Not bad for $2.00 in aluminum and a few hours of fabricating.
It was surprisingly easy. Honestly, the hardest part was coming up with the pattern, which took a lot of trial and error patterns. I am sure it isn't up to the quality of some of the manufacturer's products, but fits well. I designed it so it extended to the floor on the side to look boxed in. I think it gives it a more finished look rather than just bolted on.
Sean
'77 911S Cab Conversion
Old 08-20-2004, 04:47 AM
jakermc's Avatar
Looks great. Nice work!
1983 911 3.6L - NASA GTS-3 class
1998 Boxster - PCA SpecBoxster, NASA GTS-2
2003 996X51 - NASA GTS-4, PCA GTB
2003 996 Carrera 2 Coupe
2003 Ferrari 575M
Old 08-20-2004, 04:54 AM
constructicon's Avatar
Looks real good. I think it might have matched better if you rounded the corners off, but I see what you were doing, and it works.
You can't be neutral on a moving train
Old 08-20-2004, 05:15 AM
Friend of Warren
Looks pretty damn good to me!
Kurt V
Old 08-20-2004, 05:53 AM
Silveresrty911S's Avatar
Sean,
What kind of stock did you use? I've been tempted to do the same thing.
Rick
'76 Carrera 3.0, track
'77 3.2 targa, back home
'95 993 C4 M030, SOLD
PCA San Diego
Old 08-20-2004, 06:51 AM
GettinHeadStuds's Avatar
I'll take one, what's your paypal address?
83 SC (gone) / 72 T (gone)
Old 08-20-2004, 07:14 AM
Montana 911
k9handler's Avatar
Send a message via Yahoo to k9handler
100% markup....I will buy one from you, $4 sound good to you? Very nice work as it matches the others perfect.
H.D. Smith
2009 997.2 S 3.8 PDK
2019 Ford Ranger Lariat FX4 Baby Raptor
2019 Can Am Renegade 1000R XC
2020 Yamaha YFZ450R
Old 08-20-2004, 07:21 AM
KobaltBlau's Avatar
A friend of mine did that with galvanized sheet, but yours looks better!
Andy
Old 08-20-2004, 07:58 AM
Designer King
Paulporsche's Avatar
Nice work!
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 08-20-2004, 08:15 AM
Yellowbird RS's Avatar
Looks pretty good!
Nice work.
X/A
Old 08-20-2004, 09:01 AM
bigrubberjeep's Avatar
Looks great, but I got a question. How exacly does aluminum pedal help? I mean, it's still the stock pedal underneath right? Or does it have the beveled holes like the rennline series?
85 911 SuperSport
No more looking! The jewel is mine!
89 Jeep Wrangler
A jewel in the rough
2000 Grand Cherokee
Family Wagon with Jewels on board
Old 08-20-2004, 09:05 AM
Thanks everyone. I used a piece of 4" aluminum corner stock from a local scrap yard. They were more than happy to cut me a piece. The hardest part, like I said, was making the template for it because you have to measure on a 90 degree angle the contours of the floorboards then cut around the angle. It is hard to tell from the picture, but the mounting flange is angled forward as well. Then just a lot of measuring on the hole pattern. Actually the $2.00 was enough for 2 pedals.
Anyone who wants to try this let me know and I will measure my pattern and post it here. I actually did mine with just hand tools (9 month pregnant wife who didn't want to hear the cut-out wheel). I consider my mechanical skills minimal, so I am sure anyone can do it.
I drilled the holes to match the pedals that were already on the car. They aren't countersunk for that reason. It does give a lot of support for the left foot around some sharp corners though.
Sean
Old 08-20-2004, 09:20 AM
If you wouldn't mind...
Old 08-20-2004, 10:37 AM
}{arlequin's Avatar
what I want to know is how the hell are you guys reaching in there with a drill, near the brake/clutch pedals and are able to apply enough pressure to drill those holes????
(Mine has been duck taped, that's right DUCT TAPED, in the location for 5 months now.) I do have some problems with reach b/c of the side impact bars in the doors, but when I do get to contort and get under the dash, I'm still unable to drill through. Then I get too hot and bothered, AND frustrated, have another Maudite, and say screw it.
These results are with a brand new titanium drill bit so it's not b/c dullness. Any strategic suggestions are welcome.
..... oh, BTW, nice dead pedal. If I had the means to bend/cut diamond plate I would do the same.
dave
1973,5
Old 08-20-2004, 10:38 AM
pookie's Avatar
sfmlaw17,
I like your pedal, your car isn't black is it?
Reason I ask is my wife in I had dinner in Charlotte and I saw a black 911 that had been converted to a cab?
I live just below Gastonia on the SC side of the line. We'll have to meet up when they have the next NC Mtn run
1976 911 S Targa 3.2
Old 08-20-2004, 10:39 AM
project935's Avatar
I'll volunteer to CAD model your sketch and attempt to post a full size flat pattern for those who want to bend their own. Just let me know the dimensions ...
Project935
Tube Chassis Turbo RSR/934/935 racer - SOLD in 6/'06
Gruppe B #101
What's next?
Old 08-20-2004, 10:42 AM
I will redraw the pattern this weekend and give you the measurements. Hopefully someone with more computer knowledge can post the design that is easily downloadable. One thing, you will need to use corner stock. Flat stock will not work unless you have a metal brake to bend it. The stuff I used is 3/16 thick, way too thick to bend crisply. The scrap yard is the best place to get it. If anyone hase troubles finding any, let me know and I will get you some and mail it.
No, my cab is red. I live over by Martha River's Park off Union Road. I would love to go on one of the runs.
It is TOUGH to get to with a drill. That is partly the reason that I designed it to go all the way to the floorboard with no gaps, for the stability. From there, and a lot of patience, you can use a self-tapping sheet metal screw.
Sean
Old 08-20-2004, 11:00 AM
19 years and 17k posts...
azasadny's Avatar
Very nice, I'd buy one from you!
Art Zasadny
Learning the bass guitar
www.ford.com
Old 08-20-2004, 11:03 AM
Cymru am Byth
carmad's Avatar
I need to make a dead pedal to go with these I made, cost about $12 for the Aluminum. If you have a pattern or measurments please post them.
1986 930 (Gone but not forgotten)
1995 993 (Should Never Have Sold it)
2007 BMW 328Xi Sport Wagon
2005 Lexus GX470 Offroader
Julian Williams
Old 08-20-2004, 11:32 AM
Randy Webb's Avatar
What we really need is to have the entire pedal cluster made out of Al.
This looks nice tho...
Old 08-20-2004, 06:36 PM
