-   -   Can I add an AC vent? (http://forums.pelicanparts.com/porsche-911-technical-forum/179229-can-i-add-ac-vent.html)
justesen 08-24-2004 12:07 PM
Here is a picture from "seat level on the drivers side" in my 77 911 of the "HVAC Box" on the firewall.
http://forums.pelicanparts.com/uploa...1093374241.jpg
Can I drill a 2 1/2" hole in the air box without damaging anything inside? I'll then run an AC hose to a vent that will be mounted on top of the console. This is a "home made" attempt to get better air flow than provided by the stock vent system.
Thanks,
Jay
77 911S
no substitute 08-24-2004 12:54 PM
I recall something about an oversize vent that might do the same thing. Maybe someone can recall the details.
Paulporsche 08-24-2004 01:11 PM
I think that will work.
BTW what is that seam? Was this area modded by you or a PO?
Let us know how it works out.
justesen 08-24-2004 01:35 PM
Paul,
As far as I know, the seam is "stock". I'm the second owner and the original owner had nothing done to the car. It only has about 37,000 miles on it.
Jay
david914 08-24-2004 02:24 PM
Try this...http://www.scottsind.com/Navigation/PartsForSale/PartsForSale.htm
Paulporsche 08-24-2004 04:14 PM
Jay,
I have the bulkhead vent that David shows in his link. It goes in that area. It came w/ the car so I don't know what it costs. It works fine. You may get away w/ your low cost variation just fine. You just won't have the directability of the vent.
justesen 08-24-2004 04:20 PM
Paul,
Does the vent mount right on the "air box" under the dash? Do you have a picture?
Thanks,
Jay
Paulporsche 08-24-2004 07:32 PM
Jay,
I don't have a pic, but the vent sits on the face of the box, just below the seam. I just noticed I have one too. When looking at it from the seat, the centerline of the vent is about 1/2" to the left of the right edge of the console.
justesen 08-25-2004 03:39 AM
Thanks Paul. I've ordered a vent that should screw right to the box as long as I cut the holes correctly!
Regards,
Jay
