countach's Avatar
Unhappy 911 Carrera 3.2 stalls at idle
Hi, this is my first post !!
I have a 1985 911 Carrera 3.2
First of all, the car starts perfectly. When starting in cold, (fist time in the day, for example), it stands some time in the hi-rev idle, that's ok, and then goes to the normal idle at 900 RPM. But then, in 20 - 30 seconds, the car stalls like if it had an electric failure or out of gas..
If you try to start again, it don't start. Have to wait a little bit, and insist in the ignition, finally, starts, making some weird noises.
If you keep the engine revving (not idle) everything work fine.
What could be happening?
Thanks in advance...
911 Carrera 3.2
Old 08-24-2004, 01:46 AM
Driving member
jester911's Avatar
Check distributor cap and rotor.
Jerry
'86 coupe gone but not forgotten
Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason.
Old 08-24-2004, 02:34 AM
countach's Avatar
Thanks, i'll try this one..
911 Carrera 3.2
Old 08-25-2004, 01:19 AM
Slumlord
Porsche_monkey's Avatar
Vac leak causing lean condition?
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 08-25-2004, 05:07 AM
indigowhale's Avatar
Send a message via Yahoo to indigowhale
Check the condition of your spark plug wires too. If the outer sleeves break off in your hand, you probably need new ones.
Old 08-25-2004, 06:46 AM
North Coast Cab's Avatar
Tap on the ICV, idle control valve. It may be dirty, worn or sticking and not properly doing it's job. If it corrects the problem you can remove and clean with carb cleaner and a little compressed air. 10 minute project.
John
1985.5 944 GTS
Old 08-25-2004, 06:50 AM
falcon's Avatar
I had the same scenario. Turned out to be the alternator and regulator. Do a search under "3.2 low idle"
Randall
1988 911 Cabriolet (SW Chip)
2000 Honda Civic (4dr wifey mobile)
2001 Honda S2000 (daily driver)
2003 Honda Odyssey (family truckster)
1978 911 SC coupe (Sold)
My 911 Cab Pics
Old 08-25-2004, 10:11 AM
countach's Avatar
Thanks everybody... This will be very helpfull because this:
Here in Spain now there is happening a derrick's strike...
(Sorry if that are not the correct words... I mean: that little trucks/van that carry on the cars to the workshop... are in strike and all spain's roads are full of suspended cars in their borders...) LOL (sorry for my english)
So, as I worry about a stall and not start again (lately, its more and more difficult to start it after a stall), I'll wait to carry it when strike go off...
And as the car is far away that 'my confidence workshop', all your responses will be very helpfull in order to tell some non-specialited mechanic what is happenin'...
Far away means 342 miles (550 km),...
thanks! keep on!
911 Carrera 3.2
Old 08-25-2004, 10:28 AM
