LinkBack Thread Tools Rating: Thread Rating: 4 votes, 4.75 average.
douglas bray's Avatar
I've always just cut a diagonal groove with a grinder then put a cold chisel in the groove and smacked it with a hammer. That spreads the crack and it pulls rights off. Don't go so deep with the grinder that you hit the hub though.
Old 05-14-2017, 05:12 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #321 (permalink)
Sboxin's Avatar
Rear Hub Removal - 1978 911
An old thread, but very helpful - Thanks to all who have contributed . . .
Remove rear wheel hub -
Heat and big weight( 15#) on slide hammer did the job.
We had fairly new rear bearings and that may have made the removal more difficult.
Why remove a fairly new bearing . . . because we broke the left rear stub axle, hub
and brake rotor while racing - - maybe 40 year old parts and running over track
curbs contributed to the failure - so we are replacing with new parts the hubs, stub
axles, brake rotors and bearings (of course because you have to destroy the bearing
getting the hub out).
Regards,
Photos :
Heat on trailing arm - 15# on slide hammer -
Arn tool to remove bearing - easy and smooth
Left rear stub axle, hub and rotor failure - big sticky Hoosiers, etc. etc...
Roy T
2002 Porsche Boxster S Cobalt Blue/Blk/Blk
Crew Chief for Son's 1978 Porsche 911SC Brown 3.8L NASA race car
Previous Porsches: 1958 356 Red Coupe - 1972 914 Blue -1972 911T Coupe Aubergine
Old 02-14-2018, 07:19 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #322 (permalink)
Brap
tmaull's Avatar
Potentially dumb question:
1) Do I need to remove the axle from the transmission before I remove the rear wheel hub using a slide hammer?
1980 911SC Coupe 3.4
1995 Miata
2005 Tacoma
2009 Street Triple
Old 05-15-2018, 03:50 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #323 (permalink)
safe's Avatar
You need to remove the axle from the hub.
So you could split the axle at the hub CV.
Magnus
911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. Just works!
911T Coupe -69, 3.6, G50, "RSR", track day. Sorting out issues...
924 -79 rat roddy...
931 -79 under total restoration...
Old 05-15-2018, 03:57 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #324 (permalink)
Thank you john
for the post I'm in the process of restoring a 911 1983 dog it's a lot of fun coming from the VW world cleaning up is the hardest putting it back together that's when the fun starts
Old 01-10-2019, 03:11 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #325 (permalink)
