-   -   Wil Ferch Where is the calculator? (http://forums.pelicanparts.com/porsche-911-technical-forum/179311-wil-ferch-where-calculator.html)
mb911 08-24-2004 07:19 PM
Wil or maybe someone else can help,
Where do I find the ride hieght and corner balance calculator. I am going to change spring plates and bushings this weekend and need to figure this stuff out. Thanks so much
Ben
Rot 911 08-24-2004 07:29 PM
Go here and scroll down to the Porsche 911 Section: http://vintagebus.com/
1974carrera 08-24-2004 08:00 PM
Here's a link to take you to it:
http://tech.rennlist.com/911/pdf/settings.pdf
Zeke 08-24-2004 08:02 PM
I know more about what's going on here than most because I supplied the parts. Ben, THIS THREAD IS USELESS W/O PICS! ;)
rattlsnak 08-24-2004 08:06 PM
I just used it today when I installed my rear bars. I wont know for awhile if I did it right because the engine is still out
Wil Ferch 08-25-2004 06:15 AM
Sorry for responding late to this....but I see others have chimed-in for me. Thanks, all.
The calculator seems to work well, but it requires accurate "input" data to get good "output"...not really surprising. Total weight, fr/rr weight distribution is key.....
---Wil
widebody911 08-25-2004 06:25 AM
Here is the spring plate angle calculator
http://vintagebus.com/cgi-bin/spring.cgi
And the corner balance calculator
http://vintagebus.com/cgi-bin/balance.cgi
rattlsnak 08-25-2004 06:45 AM
Wil, i used it and came up with a spring plate angle of @18 which seems to be not enough. I know the 31 bars are very stiff, but without the engine in the car, its almost where it needs to be now! (the initial angle was @35)
I used the following specs, weight:2200, droop height:3.2, bars:31, and got 17-18 degrees. Well at least I have adjustable spring plates so it will easier to correct if Im off!
Wil Ferch 08-25-2004 07:02 AM
I'm not going to to do individual situation math checks....:)
but I will say that if the all the input data is correct ( total car weight....fr/rr distribution which is typically 40/60 for non Turbo....plug in the TB sizes...and assume you're targeting Euro ride height ...about 3.84" spring plate angle droop when car is on-ground).....then...this should all work out to within 1/4" or better of your targeted ride height.
Sure beats guessing and doing this whole mess over 3-5 times !
---Wil
mb911 08-25-2004 09:50 AM
Thanks found it! I will go ahead and tear into it. Anybody now where I can set default for rear alignment when I am done?? Of course I will have it done properly just wanted to know if I could do it myself
Ben
widebody911 08-25-2004 10:52 AM
I just scribed a line where the spring plate met the trailing arm before I took things apart, and matched that up when I put it back together. Close enough for govermnet work, and I was actually only 1/2 degree off on toe and 1 degree shy on camber. I think the eccentrics are an 11mm allen.
Another thing to consider: I installed Elephant Racing monoballs and polybronze bushings last weekend, and I noticed the spring plate bolts were kind of haggard, so I replaced all of the hardware with the exception of the eccentrics. The spring plate bolts and eccentrics are 12x1.5mm I bought slightly longer ones and used nylocks instead of plain nuts. I also chased the threads on the eccentrics.
mb911 08-25-2004 11:54 AM
Good idea thats what I will do.
Ben
