-   -   Possible alternator Problem? Help! (http://forums.pelicanparts.com/porsche-911-technical-forum/179394-possible-alternator-problem-help.html)
wanabe911 owner 08-25-2004 08:47 AM
86 911 Carrera
Hello All, Im the new owner of a 1986 Carrera, (yeah) Fist Porsche! Well it seems to have some problems and I would like to see if anyone can help me with what I think to be the most pressing issue. When driving at night with lights on, the lights dim and brighten when above 2k RPM's, does not do this at idle. I have not tested the Volts at the battery with the engine running yet (will do so tonight) I had to replace the fan belt and shims today since the belt was stretched beyond any tightening and was missing 1 shim, so I purchased 6 new ones and a belt. Could this be my alternator or regulator (or both)? Prior owner has a receipt for a reman alternator from less than a year ago.
Thanks in advance!
john walker's workshop 08-25-2004 08:51 AM
bizerk regulator. problem is, it's mounted on the alternator, and it's brushes wear out the commutator ring in the alt, so you need a new alt/reg unit. very common. check the fluid level in the battery too.
wanabe911 owner 08-25-2004 08:56 AM
Great! Thanks for the response! I will check all that tonight!
