Bluish smoke on start up
I have a 1987 Carrera with 65,000 miles. It recently started blowing bluish smoke out the exhaust on starting up. It goes away rather quickly to be replaced by a blackish smoke that disappears quickly. I had a major service at 62,000 miles that included resetting resetting valve clearances among other things. I had an '82 that also blew smoke but it was clearly an oil eater. The '87 doesn't use much oil between changes. Any thoughts? Thanks.
Old 08-25-2004, 11:17 AM
geof33's Avatar
Don't worry... Totally normal...
GruppeB #935
84 Carrera Targa B.A.S.T.A.R.D. (for sale)
82 SC RSR Project (on ebay)
95 Dodge Ram 2500
03 Toyota 4runner
Old 08-25-2004, 11:31 AM
aj88cab's Avatar
My '88 did (does) the same blue smoke thing when starting in the morning. I have found that if I let the engine idle 10-15 seconds before shutting it off it does not smoke at start-up. I watch the oil level guage and when it stabilizes I shut her down. Seems to work everytime.
Good Luck
Andrew
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires
'86 944NA, Sunroof Delete, Track Rat, Full Cage
'72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic
Old 08-25-2004, 11:56 AM
Andrew,
Many thanks for your response. I'll give it a shot.
Dave
Old 08-25-2004, 12:05 PM
Venetian's Avatar
Just a point of interest, mine used to puff blue smoke after each start-up which everyone says is normal. However after having the valve guides done, it rarely puffs now.
1987 Carrera, Venetian Blue.
Old 08-25-2004, 01:05 PM
