-   -   Replacing Plug Wires (http://forums.pelicanparts.com/porsche-911-technical-forum/179563-replacing-plug-wires.html)
pryord 08-26-2004 06:54 AM
How do I remove the wire that goes to the coil? It seems like it's permanently connected to the darned thing and I'm afraid to just yank on it.
..and by the way, why did my old braided wires need a ground and my new wires don't.
THANKS!
RoninLB 08-26-2004 06:56 AM
peel back the rubber boot till it's inverted.
pryord 08-26-2004 12:19 PM
I can get the rubber boot back, but does the wire just then pull out. It seems pretty tight, so I was hesistant to just yank it.
ruf-porsche 08-26-2004 12:38 PM
Just give it a yank once you have the boot off the coil. I thought you were replacing the wire so if you do damage the wire with the big yank it no big lost.
Someone at PORSCHE thought the backfiring that was blowing up all the airboxes was due to the spark plug wire so they decided to shield the wire.
pryord 08-26-2004 12:53 PM
All-righty then.
rickeolis 08-26-2004 01:03 PM
I ran into this problem myself just last week.
I took a pair of pliers and grabbed the plug at the thickest point and turnd it slightly until I felt it break free, then it came out easily.
Good luck.
slater 08-26-2004 05:07 PM
I pried on mine with a flat head screwdriver until the thing popped out. Of course, I replaced the coil, too.
djmcmath 08-26-2004 06:41 PM
Mine is an '86, but it seems similar: just pull real hard, and it'll come. I put it back on when I was done putting the engine back in, and the car still runs, too, so I don't think I did much damage.
Dan
