I've got a minor problem; My defroster levers won't stay up. There's a little nut on the side of the levers and when I tighten it - it always loosens back up. Seems to me that it needs another nut on there to tighten down on that but I'm not sure. I figured that would be a good fix but I wondered it if was supposed to be there in the first place?
Anyone know?
-The Mikester I heart Boobies |
maybe they aren't adj. right at the heater boxes? I'd check that - maybe the tension is pulling the levers down.
Re: Heater levers won't stay up.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Unregistered
How long is it going to take for someone to mention Viagra? Oops, just did. Sorry about that
Administrator
Rusted heater boxes? Corrosion in the sleeves of the cables?
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
Well, I guess I'll check the tension at the boxes - I just wasn't sure how tight the assembly between the seats should be as it seems loose to me and when I tighten it up it just loosens right back up pretty quickly.
"when I tighten it up it just loosens"... meaning when you pull the lever to its full extension it falls back down ?
try a new self locking nut, or get a couple of thin jamb-nuts.
Ditto on what JohnW said, it sounds like the lock nut is history. Try a new one, or get a punch and dimple the edge of the old nut, on one side of its face, so it deforms the nut into the thread area a little, it should then stay in place.
84' Steelslantnose Cab. 1953 Dodge B-4-B-108" 90,127 miles 1953 Dodge B-4-C-116" 58,146 miles 1954 Dodge C-1-B8-108" 241V8 POLY 1973 Roadrunner 440-SIX-PACK* 1986 F-250 Super Cab-460 V8 tow Newest additions- Matching numbers 1973 340 Road Runner!! 1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles others... |
Guest
Posts: n/a
Viagra!
Cialis rules!!!!!
At least my blonde wife thinks so. Mel |
but the levitra chick looks so happy.
