-   -   CIS basic mixture adjustment (http://forums.pelicanparts.com/porsche-911-technical-forum/179654-cis-basic-mixture-adjustment.html)
fireant911 08-26-2004 03:04 PM
I have just finished reading the Bosch Fuel Injection & Engine Management by Charles Probst. My question is the difference in setting the basic mixture adjustment without the gas analyzer: the K-Jetronic with Lambda is recommended to use a dwell meter connected to the test connector to a target of 45 to 55% whereas the Motronic is set (again, if no gas analyzer is available) by hooking up a voltmeter to the disconnected Oxygen Sensor and adjusting the 3mm screw until finding the midpoint between the lowest and highest sensor output which is about 500 mV. I realize the best method is with the gas analyzer but that is not currently in my budget. The target should be so that open loop and closed loop are the same value. Can the latter method (Motronic) be successfully utilized when attempting to set the basic fuel mixture in a 911SC?
sammyg2 08-26-2004 03:41 PM
Yes, it can. I do just that, but with an air fuel ratio meter.
No, it isn't as accurate as a wide band, but it will get you in the range.
Bavsport 03-10-2008 08:19 PM
O2 Sensor Voltmeter Values?
I used this method just yesterday with great results.
I Found these specs on the internet
http://forums.pelicanparts.com/uploa...1205204846.jpg
I used a fluke meter reading millivolts and read the o2 sensor. I adjusted the mixture and set mine to 865mV. I don't know how accurate this is but my car idles very smooth and revs all the way to the way to 6k with no backfires, pops or anything.
Scott
emac 05-14-2008 07:21 AM
Scott
Sent you a PM
SCWDP911 05-14-2008 11:00 AM
sub'd
