-   -   Removing Clutch fork (http://forums.pelicanparts.com/porsche-911-technical-forum/179665-removing-clutch-fork.html)
scoll911 08-26-2004 03:57 PM
Hey, how do I remove the clutch fork -- I've seen other pictures and there is normally a bolt. My fork does not have the bolt?
http://forums.pelicanparts.com/uploa...1093561042.jpg
yelcab1 08-26-2004 04:00 PM
Turn the fork on its axis until you see a retaining pin through the fork, it's about 1/8 of an inch thick, almost an inch long. Drive it out with a drift of an appropriate size and remove the shaft while the fork falls out. Don't forget to lube it and to replace the rubber seals.
