concentric's Avatar
Question Removing fuel tank - '74 911
Ok...
I'm on the attack against the junk in her trunk. I've got some rust issues in the front near the battery tray, so I've been doing some grinding in the front area. I noticed that some of the rust extends down into the junction where the tank seals to the frame, so it's time to drop the tank.
Can anyone give me a rundown of how I can drain the fuel, drop the tank, and get this done without destroying anything in the fuel system? I think I have the idea, but I'm looking for confirmation:
1. Disconnect fuel hoses into container and drain excess fuel.
2. Pinch hoses leading to rear of car so fuel will not run out and drain fuel pump dry.
3. Remove electrical connection from fuel tank sender
4. Remove clear hose that goes to somewhere on top of tank and hose that connects fill stalk to tank.
5. Support tank with board from underneath and jack up to break seal.
Any thing I've left out or issues that I should check into addressing while I do this process?
Thanks,
Jason
Stuff of marginal consequence:
- 1974 911"Carerra" sunroof coupe
Old 08-27-2004, 01:12 PM
Montana 911
k9handler's Avatar
Send a message via Yahoo to k9handler
sounds like you have it...just be careful not to bend the spouts where the return/pump lines connect.
H.D. Smith
2009 997.2 S 3.8 PDK
2019 Ford Ranger Lariat FX4 Baby Raptor
2019 Can Am Renegade 1000R XC
2020 Yamaha YFZ450R
Old 08-27-2004, 01:47 PM
Kevin Taylor's Avatar
I hope you disconnected the battery?
1973 911 E 2.4 MFI
1965 Devin - 1967 912 Power Plant
Old 08-27-2004, 02:30 PM
concentric's Avatar
I haven't done the FT removal part of the project yet, but fuel and spark don't mix well where eyebrows and face are near.
I actually will have the battery removed since it will be in the way of the project and grinding.
Jason
Old 08-27-2004, 02:33 PM
I would rather be driving
jpnovak's Avatar
I didn't see it mentioned, and I'm generally a smart -a ss so don't forget the three allen head cap screws and brackets holding the tank in place. One in teh center and one to the left and right.
Other than that, you are all set.
If the car is drivable, run as much gas as possible out before you start to drain. YOu will be surprised how much gets in there. Clean the tank while its out so you don't have to do it later. 30 years old is bound to have some rust, dirt, old gas in there. There are many methods to clean the tank. Search the archives.
You may notice that rust has migrated to the lip seam around the tank. Clean and treat this as well.
Good luck
Old 08-27-2004, 03:00 PM
concentric's Avatar
Good luck
Yeah, you got me on the brackets there... I didn't put them on the list. They've been staring me in the face for a couple days while I've been working on this... That's the type of stuff I normally forget to add to lists and tell my wife! The obvious.
Thanks, JP.
J.
Old 08-27-2004, 03:11 PM
Randy Webb's Avatar
Noah -- I thought the idea was to leave the bung alone -- let sleeping rust dog particles lie and not stir them up?
Old 08-27-2004, 03:47 PM
