TurboRuf's Avatar
930 Spring Plate / Ride Height Adjustment
I’ve recently noticed that my left rear wheel on my 85 930 was starting to slightly rub the fender well. I pulled the tire and noticed that the bolt below was loose and hanging on by just a couple of threads. I tightened the bolt but it’s still rubbing. Does this bolt affect ride height? What can I do to correct the problem?
Thanks!
85 930 Ruf BTR
Old 09-08-2004, 06:33 AM
Toe Adjust Techniquest
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 09-08-2004, 06:42 AM
djmcmath's Avatar
If I'm reading your diagram right, and if the 930 suspension is like the Carrera, that's the eccentric bolt on the springplate. Hmmm ... Check out the tech article: http://www.pelicanparts.com/techarticles/911_suspension_bushings/911_suspension_bushings.htm on the topic, perhaps?
Going fore to aft on the spring plate, the first big bolt (24mm front and back) is the fulcrum about which the spring plate rotates. The second (24mm front, 36mm back) is the eccentric ride height adjustment nut. The two closer to the wheel are for toe-in and camber (iirc, I never touch them). If the 24/36mm nut has come loose, your ride height will be ... random, at best.
To solve this problem, you'll need to go through the ride height routine as Ronin points to above. You also have the interesting complication of probably having pulled that silly bolt out of place. I loosened that particular 24mm nut too far once and discovered that the eccentric bolt will only go in correctly in one spot.
Good luck, let us know what you do with it.
Dan
'86 911 (RIP March '05)
'17 Subaru CrossTrek
'99 911 (Adopt an unloved 996 from your local shelter today!)
Old 09-08-2004, 09:39 AM
TurboRuf's Avatar
Thanks guys, I appreciate the info!
85 930 Ruf BTR
Old 09-08-2004, 07:11 PM
