-   -   Ballast unit missing (http://forums.pelicanparts.com/porsche-911-technical-forum/180118-ballast-unit-missing.html)
stevef 08-29-2004 03:07 PM
With much thanks to Early S man I know know why my tach doesn't work. No ballast unit. Anybody know where a ballast unit for a 1971 2.2T can be had. Does our host have them. Is there a substitute? Can one be fabricated. I'm sure it is some kind of big resistor.:confused:
stevef 08-30-2004 09:31 AM
bump... anybody?
Fishcop 08-30-2004 06:02 PM
Okay, I'll go out on limb... I'm fairly sure any 12 volt ballast resistor will do the job. They should be available at automotive supply shops. I replaced the original in my car when I upgraded to a Crane XR700. It came with the Crane coil. It looks very different to the original Bosch being ceramic as opposed to the Bosch alloy and epoxy. I suspect the price will not be too much and not worth fabricating your own.
Zeke 08-30-2004 10:49 PM
Where is the thing?
Fishcop 08-30-2004 11:37 PM
On my 69 I found it on the left side of the engine bay with the relays.
Fishcop 08-30-2004 11:54 PM
Oops, I have been corrected and informed there are two different kinds, one for the primary coil and another for the tacho... So please ignore me :)
Early_S_Man 08-31-2004 08:52 AM
There are actually three ballast units available ... all are three-terminal resistive dividers, all have three 'pigtail wires' with terminals on them, and are all mounted on the relay plate/panel!
For battery-coil ignitions, there are two, both are shallow rectangular boxes:
Beru ... 901.602.852.00
Bosch ... 901.602.853.00
For CDI ignition, there is only one, and it is cylindrical, aluminum can, taller than a round relay ... 901.602.601.00
The CDI and battery-coil devices aren't interchangeable, and I don't have the resistance values.
