H20911's Avatar
towing a 911
So it looks like I have another Hurricane coming my way (florida)
I might get outta dodge if I am in the projected path. Right now Francene (or how ever it is spelled) is headed to florida and I am hoping that it will turn. I really do not think that My house will take a strong cat 3 or 4 on a direct hit.
so the question is
if I tow my 911 behind My jeep Grand cheoke will it drag okay on a dolly? I was thinking about putting the front wheels on the dolly and dragging the rear wheels with it in neutral would the be okay?
I Know that a carrier would be better but the dolly will be it this time....no access
thanks for your help
h20911's V8 Homepage
www.home.earthlink.net/~sdfranco/index.html
Old 08-30-2004, 02:28 PM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
Done it, it's ok if you weight it right and go slow. But if you can get something larger I would. I towed mine 850 miles from Milwaukee,WI to Greensboro, NC.
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 08-30-2004, 02:48 PM
yogi's Avatar
My house will not survive either. I'm going to park my car at the inside part of a multilevel garage, near the middle. Like the kind you see at an airport or hospital. I'll try for the first or second level. They had a show on hurricanes on TLC or the Discovery channel and they said the wind is really reduced at the inside of a mutilevel garage. Good luck with storm.
Jerry Baer
87 Carrera Coupe
Old 08-30-2004, 04:23 PM
TMH TMH is offline
TMH's Avatar
I asked my wrench about towing with a dolly (rear wheels on the ground). He said no.
With that said, however, one of the chief instructors at a driving school I attend tows his track car this way, with apparently no ill issues. For your need, you should be just fine using a dolly.
Good luck and stay dry.
Tom
Ain't life grand?
Old 08-30-2004, 04:30 PM
Gordo2's Avatar
Trailer vice Dolly
Go with the full trailer vice dolly.
I moved recently and planned to use a dolly for my '83. The day of the move I loaded my car up on the dolly and found that the clearance at the rear, no matter which end of the car was on the dolly didn't leave any room for dips or bumps. It may have made it, but the ride would have been miserable with me wondering which bump was going to thrash the underside of my car. I swapped with a full trailer and didn't think twice.
Gordo
Don "Gordo" Gordon
'83 911SC Targa
Old 08-30-2004, 09:16 PM
I used a tow dolly and removed the CV axles. Don't think you want to have the tranny spinning in neutral like that for very long. You can tow it backwards as well, but that may tax the steering lock a bit.. maybe?
Current: 1975 911S --Chocolate brown
Past:
1967 911S --Bahama Yellow
1990 C2 Targa --Silver
1973 914 2.0 --Delphi Green
Old 08-30-2004, 09:36 PM
kqw kqw is offline
Why not just drive it to a safer place out of the path of the storm?
The Fox
Carrera
Old 08-30-2004, 09:46 PM
You can flat tow it or dolly it with no problems. The 911 tranny will not be damaged by towing.
-Andy
Old 08-30-2004, 10:06 PM
Blockchain Tech Inventor
jrdavid68's Avatar
Here's how I get to the track:
A Mean Green Lifted 1972 C10
Long live the king!
Old 08-30-2004, 10:49 PM
hey guys, great info!
what about with the tranny out of it? for obvious reasons the axles will come out.
any problems with unbolting the axles from the allen screws that hold it to the hubs/shaft? if i pulled out the entire axle, (removed from the hub itself) nothing will hold the hub to the rear trailing arms...
i know i read somewhere where you're not supposed to push or move the car with the axles removed..are we talking the axles removed from the entire hub? or axles from the hub shaft? or both?
just want to clarify!
(hmmm.hope that was confusing in itself!)
'76 p-car
'98 mitsubishi eclipse
looking for a '69 912 any leads?
Old 08-31-2004, 11:19 PM
