915 transaxle type
Does anyone know how to tell if the transaxle is limited slip or not and which oil to use? Also how difficult should it be to rotate the output shaft for gear selection and which positions as far as in and out and rotated position are which gears when not running?
Any help would be great as I am new to porsche and this forum.
Thanks.
Old 04-25-2013, 05:25 PM
schumicat's Avatar
raise rear end turn one wheel with hand, if the other one spins opposition direction no lsd.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 04-25-2013, 06:03 PM
gearhead
If it was an original LSD gearbox it will have a 12 between the type number and the serial number. So it would start with 915/44 or 915/61 or similar 5 digit type number then either a 12 or no 12 plus another half a dozen numbers.
This is on a rib on the bottom of the main case. The problem is many gearboxes were dragged on shop floors and numbers are gone and many LSD boxes had the LSD "borrowed" for racecars. You need to do the axle spin test to see if it has an LSD in it today.
Old 04-25-2013, 09:54 PM
Aluminumsphr, the main gear shaft should be easy to push in and out, as well as rotate cw and ccw. There are detent springs whose resistance you will have to overcome. Look up "915 tutorial" for some great info.
Old 04-25-2013, 10:42 PM
