Got a new flywheel from Pelican; but it's all oily! How to clean?
Alright, what's the best way to prepare a new flywheel for installation? My new flywheel was packaged in oil to prevent rust, I presume, but how do I properly clean it?
Oil ruined my last clutch; I want this one to be flawless! Thanks for your help. Brian
'73 Alfa Romeo Berlina '78 Porsche 911SC, '05 Porsche Cayenne S '88 BMW 325iX, '00 323i, '06 325i, '07 328i Touring '94 Toyota 4Runner 5 spd, '89 Jeep XJ 5 spd |
After you get it bolter down and torqued onto the crank, right before you attach the cluch spay the crap out of it with brake cleaner to get all the oil off the friction surface, don't spay into the center of the crank or you will have to regease the pilot shaft bearing. (you did replace it didn't you).
Keith Epperly 87 slant nose turbo look carrera cabriolet |
Author of "101 Projects"
Uh, spray prior to mounting it, so you don't have to worry about the brake cleaner affecting anything important...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Not as it seems
possibly was it oiled (lightly) by the manufacturer after finishing to prevent any rust from developing during storage and shipping? i mean light rust/corrosion?
i second the brake cleaner method.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
Friend of Warren
Brake cleaner or lacquer paint thinner PRIOR to installing!
Kurt V No more Porsches, but a revolving number of motorcycles. |
Senior Member
Yep, brake cleaner. Evaporates, leaving no residue. That's not true of most solvents. Laquer Thinner is a good solvent, but does leave some residue. Brake cleaner and alcohol are my two favorite final rinses.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
I would wash it in solvent and spray the pressure plate contact surface with the brake cleaner after installation. You will be handling the flywheel and get the surface soiled. The solvent will leave a little beneficial residue on the non contacting surfaces.
Wayne makes a point about potential damage from errant BC, but you can control the spray and protect from it running down the backside and rinsing off your RMS. Just use rags or paper towels. You can stuff a small rag in the pilot hole. Be sure to properly air out rags so they don't spontaneously combust. This way, you won't be using much BC and you can be sure your contact surface is not smudged with oil, asssembly lube or dirt. |
Be sure the clean and inspect the mounting surfaces for any dings or other damage before installation. These two mating surfaces need to be clean and debris free..
Chris |
thanks for the advice. i thoroughly cleaned the flywheel with brake cleaner BEFORE installation, and sounds like i'll give everything one last wipe down before it goes together this morning.
i agree with superman, alcohol and brake fluid make superb final rinses... brian
Or you could hang it in the water tank of your comode for a few days untill clean then install,enjoy!!!!!
