Wish me luck...the "dreaded heat exchanger removal" tomorrow!
I got my new Fabspeed muffler setup today, and my car got smogged yesterday. So, I'm ready to start on the B&B install tomorrow. I'm stocked up on O2 and Mapp gas, and I think I'll get a tungsten cutter for the Dremel for good measure...BTW, has anyone tried Island911's method of cutting the nuts off?
I'm assuming if I need to resort to cutting, you put the bit parallel to the stud, and start cutting the nut from the outside stopping before you get to the stud? I'm going to try heat first, but it's going to be tough working the torch while keeping my fingers crossed!
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
You do not have permissi
Never done it but it looks like a difficult job. Heat the nut up quickly and evenly and spray PB Blaster to cool it down. Hold breath, repeat.
Senior Member
Ed,
Might try some penetrating oil on the nuts the day before. Like John said, if they get difficult heat is the best way. JoeA
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
ed, good luck.
i used mapp gas. ALOT easier with two people. my friend worked the torch and i held the socket a few inches away. when he got it glowing red, i put the socket on it and popped it off. i didnt break a single one. one or two, held tight and all we did was lay into it with the torch again. we did have the dremel, to island method the stubborn ones, but it wasnt needed. kick some a$$ tomorrow. the barrel nuts were cake. cliff
poof! gone |
how much torque do you suppose will shear those suckers? maybe a torque wrench set on some conservative critical setting can prevent disaster?
poof! gone |
I didn't have to use heat or any other method other than soaking them in Prolong overnight to get mine off. Now getting them back on is another story unfortunately
![]() I say give it a go without any drastic measures and see if you can get 'em off, if not then start with the torch.
Amir '83 911SC |
In looking at the nuts, I don't see how PB will put a dent in them. My thought is the heat is fairly simple, and will provide some insurance against torqueing a stud inadvertantly. When I took my cat off, it worked real well.
Somatic Negative Optimist
Two people. One operates the torch: red hot barrel nuts. The other is ready with the proper long Allen socket. Worked fine. Soak them the night before.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
