carb jets on webers
Will changing from stock air filter to ITG foam filters require any adjustments to the carb settings? I have weber 40's.
'68 911 2.2 "E" PMO Carbs, Electromotive Crankfire Ignition, Adjustable Spring Plates, turbo tie rods, Bilsteins, headers, MB911 muffler... "The sea merely lies in wait for the innocent but it stalks the unwary." |
I would rather be driving
shouldn't require any changes. YOu may have to adjust the idle mixture but only if the stock setup was dirty.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
