billyboy's Avatar
carb jets on webers
Will changing from stock air filter to ITG foam filters require any adjustments to the carb settings? I have weber 40's.
'68 911 2.2 "E" PMO Carbs, Electromotive Crankfire Ignition, Adjustable Spring Plates, turbo tie rods, Bilsteins, headers, MB911 muffler...
"The sea merely lies in wait for the innocent but it stalks the unwary."
Old 09-03-2004, 07:22 AM
I would rather be driving
jpnovak's Avatar
shouldn't require any changes. YOu may have to adjust the idle mixture but only if the stock setup was dirty.
Old 09-03-2004, 07:52 AM
