Got a new flywheel from Pelican; but it's all oily! How to clean?
Alright, what's the best way to prepare a new flywheel for installation? My new flywheel was packaged in oil to prevent rust, I presume, but how do I properly clean it?
Oil ruined my last clutch; I want this one to be flawless!
Thanks for your help.
Brian
'73 Alfa Romeo Berlina
'78 Porsche 911SC, '05 Porsche Cayenne S
'88 BMW 325iX, '00 323i, '06 325i, '07 328i Touring
'94 Toyota 4Runner 5 spd, '89 Jeep XJ 5 spd
Old 09-02-2004, 08:21 PM
After you get it bolter down and torqued onto the crank, right before you attach the cluch spay the crap out of it with brake cleaner to get all the oil off the friction surface, don't spay into the center of the crank or you will have to regease the pilot shaft bearing. (you did replace it didn't you).
Keith Epperly 87 slant nose turbo look carrera cabriolet
Old 09-02-2004, 08:27 PM
disband
juanbenae's Avatar
possibly was it oiled (lightly) by the manufacturer after finishing to prevent any rust from developing during storage and shipping? i mean light rust/corrosion?
i second the brake cleaner method.
Old 09-03-2004, 07:55 AM
Friend of Warren
Brake cleaner or lacquer paint thinner PRIOR to installing!
Kurt V
Old 09-03-2004, 08:10 AM
Senior Member
Superman's Avatar
Yep, brake cleaner. Evaporates, leaving no residue. That's not true of most solvents. Laquer Thinner is a good solvent, but does leave some residue. Brake cleaner and alcohol are my two favorite final rinses.
Mocha 1978 911SC. "Coco"
Old 09-03-2004, 08:16 AM
Zeke's Avatar
I would wash it in solvent and spray the pressure plate contact surface with the brake cleaner after installation. You will be handling the flywheel and get the surface soiled. The solvent will leave a little beneficial residue on the non contacting surfaces.
Wayne makes a point about potential damage from errant BC, but you can control the spray and protect from it running down the backside and rinsing off your RMS. Just use rags or paper towels. You can stuff a small rag in the pilot hole. Be sure to properly air out rags so they don't spontaneously combust.
This way, you won't be using much BC and you can be sure your contact surface is not smudged with oil, asssembly lube or dirt.
Old 09-03-2004, 08:26 AM
Be sure the clean and inspect the mounting surfaces for any dings or other damage before installation. These two mating surfaces need to be clean and debris free..
Chris
Old 09-03-2004, 08:27 AM
thanks for the advice. i thoroughly cleaned the flywheel with brake cleaner BEFORE installation, and sounds like i'll give everything one last wipe down before it goes together this morning.
i agree with superman, alcohol and brake fluid make superb final rinses...
brian
Old 09-04-2004, 07:56 AM
Or you could hang it in the water tank of your comode for a few days untill clean then install,enjoy!!!!!
Old 09-04-2004, 08:38 AM
