-   -   wire in multi-pin engine connector (http://forums.pelicanparts.com/porsche-911-technical-forum/181005-wire-multi-pin-engine-connector.html)
Randy Webb 09-03-2004 10:05 PM
The 14 pin engine connector from a 1986 engine has two red wires in it. #14 seems normal -- it's the alternator wire. The other red wire goes to pin #2 on the connector.
pin 2 is always hot (has +12 volts even when the key is off). What's wierd is that when I turn the key on (with the battery disconnected) pin #2 has continuity with ground (but not when the key is off). This doesn't seem right to me.
Is this normal?
And what does the pin 2 red wire do on a Carrera engine anyway?
Thanks.
