83SC CIS help needed
I recently replaced my fuel pump on my '83SC and had trouble getting it to start and run. It would start and within a few seconds would die, you could smell the fuel like it was flooded. After letting it sit for about a week, it seemed to correct it self. I got it to start, it really blew some black smoke for a few minutes and now the next problem:
Now (cold start) I can get it to start and idle but it is slow to rev and I can hear small backfires (I have a pop-off valve installed). When the temp goes up after about 2 minutes of idling it will rev freely with no misses/hesitations but it will not idle. I can hold the rev's around 1000 rpm or so and give it gas and it seems to be fine though the rpm range but if I let off the throttle it will just die. any suggestions on what to start looking at? thanks |
Is there a new check valve on the new pump? Accumulator getting old? If it does not settle down, a volume check for the pump and/or pressure settings check.
| All times are GMT -8. The time now is 01:43 AM. |
