na2ub's Avatar
Deleting Bumperettes, Move the plate lights where?
I would like to delete the huge bumperettes on my 79 Targa, but I am not sure what to do with the license platet lights that are housed in them. I suppose I would need to remount them in the smaller bumperettes or something alike. So for those that have done it, what did you do?
Doug
Doug
79 SC Targa w/ ITBs, 2004 Cayenne Turbo
Old 09-05-2004, 09:45 AM
Glasgow 911SC's Avatar
I believe you can get number plate bolts that double up as (LED) number plate lights. I'll see if I can find where I saw them.
Chris
1982 911 SC Hellblau Metalic
1997 Boxster 986 2.5l
Old 09-05-2004, 09:55 AM
KTL KTL is online now
Schleprock
KTL's Avatar
Check out this topic:
Bumper Pad Removal Discussion
Kevin L
'86 Carrera "Larry"
Old 09-05-2004, 09:57 AM
Where is that wrench?
EdT82SC's Avatar
Here is an option:
License plate lighting option (for aftermarket bumpers)
Ed T.
1982 911SC
Porsche Wallpaper
Old 09-05-2004, 10:08 AM
na2ub's Avatar
Thanks for the ideas. I am still not really excited about plate bolts that have built in lights. I am not trying to have some sort of fancy bumper, but rather just lose the weight / eyesore of the bumperettes. I was looking for something new to mount them in. Keep 'em comin.
Doug
Doug
Old 09-05-2004, 10:10 AM
chrisp's Avatar
http://www.speedwaymotors.com/xq/asp/strBase_List./hilt./source.2192/base_no.91050135/str_base_no.000%2DCATALOG+STREET%2C7209306%2C91004 020%2C91004021%2C910501%2C91050101%2C91050131%2C91 050135%2C91050138%2C91050175%2C91050731%2C91051300 %2C91068000%2C91068001%2C91088200%2C91130102%2C911 30103%2C91661081%2C91662012%2C92539901%2C/header_title.Street+Rod+Products%2DLicense+Plate+F rames/page_name.prod%5Flist%5Fdisplay.asp/search_type.L2%7E304/search_option./deptsearch./deptSearch_id.225/dept_id.L2%7E304/dept_id_p./dept_name./dept_name_p.Street+Rod+Products/ShowImages.yes/sq.0/cont.1/intPgNo.1/redirect./qx/product.htm
http://www.speedwaymotors.com/xq/asp/strBase_List./hilt./source.2192/base_no.91050731/str_base_no.000%2DCATALOG+STREET%2C7209306%2C91004 020%2C91004021%2C910501%2C91050101%2C91050131%2C91 050135%2C91050138%2C91050175%2C91050731%2C91051300 %2C91068000%2C91068001%2C91088200%2C91130102%2C911 30103%2C91661081%2C91662012%2C92539901%2C/header_title.Street+Rod+Products%2DLicense+Plate+F rames/page_name.prod%5Flist%5Fdisplay.asp/search_type.L2%7E304/search_option./deptsearch./deptSearch_id.225/dept_id.L2%7E304/dept_id_p./dept_name./dept_name_p.Street+Rod+Products/ShowImages.yes/sq.0/cont.1/intPgNo.1/redirect./qx/product.htm
http://www.commandelectronics.com/lighting-accessories.html
'83 SC
Old 09-05-2004, 10:47 AM
Randy Webb's Avatar
fit the early deck lid which has built in lights
get some lights mounted in pods and mount them thru the bumper
Old 09-05-2004, 11:07 AM
I removed all the rubber on my bumper. Reversed the shock bolts so the studs come out of the bumper. I drilled one small hole behind the plate and used (Lightning Boltz) in place of the license bolts. Works great.
Old 09-05-2004, 01:38 PM
Check eBay. From time to time some gems pop up, like these Hella lights, which were incidentally used on the...917 to light the race numbers
Old 09-05-2004, 01:57 PM
Carbon Emitter
jkarolyi's Avatar
Those are the ones used on my BMW 2002 also.
Old 09-05-2004, 05:36 PM
project 911's Avatar
I used some light weight plastic units from a local parts store. They were chrome but I painted them the body color. If I would have known about the LED mounting bolts, I may have gone with those.
Steve B.
1971 T 2.2 w/Zeniths
Gruppe B member 171
Mid 9 Web Site Guy
Old 09-05-2004, 07:48 PM
Friend of Warren
Originally posted by na2ub
Thanks for the ideas. I am still not really excited about plate bolts that have built in lights. I am not trying to have some sort of fancy bumper, but rather just lose the weight / eyesore of the bumperettes. Doug
Why not the license plate bolts? It is the simplest way to go. They work well and you can even tell they are there unless you have the lights turned on.
Kurt V
Old 09-06-2004, 06:37 AM
I'd, of course, agree with Kurt. I frequently get question like "what do you do at nightime?" until I point out that the bolts have lights in them.
Old 09-06-2004, 07:47 AM
na2ub's Avatar
Ok, I am conviced. I guess I will get the lighted bolts or the lighted plate frame. It did not appear that the lighted bolts produced enough light, but if you guys say they are ok, they're ok by me. Thanks for the input. I never knew such a product existed.
Doug
Doug
Old 09-06-2004, 08:08 AM
What is "enough light"? I really don't care how illuminated my rear plate is--I use a plate frame with little built-in bulbs--I just care that I can show the cop, or annual-inspection facility, that yes, the reara license plate is indeed illuminated.
Stephan
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 09-06-2004, 09:54 AM
na2ub's Avatar
Stephen. Obviously no driver cares if there even is a license plate. The point of the plate and the light is so that the police can keep tabs on you and run your plate when they are behind you. If the fuzz doesn't think your plate is well-lit, it is an excuse to pull you over, give you a ticket, run your driver's license, poke through your car, delay you, and generally big brother you. I (call me crazy) prefer not to give them that excuse. That is why "enough light" is important to me. I don't even have annual inspections where I live, so that is not even an issue.
Doug
Doug
Old 09-06-2004, 10:12 AM
na2ub's Avatar
Eastwood Co. is out of stock. Any other sources for lighted bolts?
Doug
Doug
Old 09-06-2004, 10:17 AM
Yellowbird RS's Avatar
I'm not the seller:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=35580&item=2488420454&rd=1
X/A
Old 09-06-2004, 10:34 AM
Gon fix it with me hammer
svandamme's Avatar
any details on that tranny mount of yours?
did you make your 911 mid engined? common , share it with the group
Stijn Vandamme
BIMDIESELBMW116D2019
Old 09-06-2004, 10:35 AM
It actually is my brothers G50 waiting to install. Mine was at the shop. I gave up on the mid engine idea when I realized I'd be sitting on the valve covers As far as finding another vendor, here is one http://www.truckaddons.com/Catalog/subpages/DEI_lightnbolts.htm
If this isn't viable, search the brand on google and find other. Good luck.
Old 09-06-2004, 10:58 AM
