Question on upshift light
People have said a lot about taking out the bulb, or putting a crest/tape/naked photo over it, but what about a different possibility?
Why not make it useful, and get in there (wherever "there" is) to change its input, and have it come on at 5500 or 6000 (or whatever) RPM? What do you think?
89 Carrera 3.4 "There is a right way to go around a corner - it's called the line." -- PCA DE speaker bryteside.com - good things happen. |
Senior Member
One thing you could do is to connect it to your "charging/handbrake" light bulb wiring. This way if your fanbelt came off you might see two small lights sooner than just one...
I just covered mine up... JoeA
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Re: Question on upshift light
The light does do this as previously posted. But a long time ago I removed one wire from the speedo that removed the annoying shift light to come on at 1500rpm (or whatever it wanted to do so that you could save gas). I think this modification was covered in one of the PCA UpFixin' books. So the light only comes on now about 6100 or 6200 rpm, somewhat just before the rev limiter will kick in.
...and another thing...
...has anyone figured out how to disable the annoying buzzer that sounds every time the door opens with the keys in, and when you first enter the car (seat belt reminder?)
Peace & Thanks, der Mond '87 Carrera Coupe Venetian Blue Metallic |
Re: ...and another thing...
Steve My '85 911 Targa ** Hand painted center caps for sale here RIP Warren PCA & Rennlist member |
How about reposting the procedure here? This is the definitive source for information. I would like to do the same, change it so that it comes on at a higher RPM. Really don't feel like searching the whole net to figure it out. I'll just leave it be....
Rick 88 Carrera Targa -- There are only those that know and those that do not!!! -- |
