aways's Avatar
parking brake light HELP!
The parking brake light indicator on my dash will not usually
go out when I release the parking brake. If I push down on
the brake lever, the light will go out. It appears to just be a
problem with the contact switch in the brake lever assembly or
perhaps a cable doesn't have quite enough slack? Can anyone
tell me how to adjust this mechanism? Thanks!
P.S. The parking brake is disengaged fully since the car will
roll with the brake in the down position. The problem doesn't
appear to be related to the brakes as the light will go out
with a slight downward pressure on the brake lever.
commandant of the compound
Old 07-31-2004, 10:12 AM
Brother's Avatar
B to the izump. Ditto.
I can't even extinguish mine by pushing down.
Paul
1980 911SC Targa - Sold
1972 914 - Sold
Old 09-06-2004, 09:31 PM
3.2 CAB's Avatar
There should be an adjustment slot on the brake handle housing, there is a small set screw on the right side, loosen the screw, slide the switch in the arch shaped slot till you have the light coming on and going off like it should then tighten the set screw.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 09-07-2004, 12:57 AM
Brother's Avatar
Thanks, CAB.
I also found this thread.
Brake Warning Light 1981 911 SC Targa
arking+brake+light
Paul
1972 914 - Sold
Old 09-07-2004, 04:32 AM
