-   -   Boost control Question (http://forums.pelicanparts.com/porsche-911-technical-forum/181266-boost-control-question.html)
jbryant 09-06-2004 04:10 AM
http://forums.pelicanparts.com/uploa...1094468831.jpg
I was wondering what the switch above the boost control knob is for. Has anybody seen this before and what is its likely use?
Jim
bell 09-06-2004 07:13 AM
is that a momentary or a latching switch? on our turbo dodge's we'll use cold start injectors to kick in extra fuel, or maybe a water sprayer to cool the intercooler if you have one......maybe trace where the wires coming off of it goes, to me it doesn't look stock but i don't own a 930 :)
TurboRuf 09-06-2004 07:54 AM
That looks like an Andial boost controller. I'm not sure what the switch would be used for... maybe Nitrous :D Fire in the hole!
Definitely not a stock item. As Bell suggested, try to trace the wires.
jbryant 09-06-2004 08:11 AM
Bell- It is a latching switch.
You are probable right about it being an Andial BC. The car immigrated here from CA and the PO used Andial for service, etc.
bell 09-06-2004 09:07 PM
trace the wires.....if it's a latching switch it may go to a vacuum switch which opens up that adjustable knob.
i made a controller for my dodge for 12lbs/24lbs using a toggle and valves, with it off it's more streetable......flip the switch and all hell brakes loose:D
maybe follow the vacuum line from the knob too......it may lead to a vacuum switch which is triggered by the latching switch.
but again...my turbo experience is from my TD's :)
jbryant 09-07-2004 10:10 AM
I looked on the Andial website and it is one of theirs. If it ever stops raining here I will investigate further.
If someone knows what it does and wants to jump in though...
