Factory Ride Height
I know many folks adjust ride height lower than factory spec's.
I had an alignment done recently and it was done correctly but; I now have more bump steer than I want. The wife and I took a weekend trip up to Boston from Philadelphia and unless the road was smooth, I noticed bump steer from every rut in the road. I do not want to get a bump steer kit to off set this action. What EXACTLY is the factory ride height setting? Thanks in advance.... |
A search on 'ride AND height' will answer your question in no time. Your car is definiteley too high in the pic :)
Here's a pic to tempt you to go lower and fit a bump steer kit...http://forums.pelicanparts.com/uploa...1094570996.jpg |
The factory method for determining ride height compares the centerline of various suspension components. As a simplification, most use a ground-to-fender-lip measurement of 25.5" front, 25" rear ( the cutouts are different causing a bigger number for the front).
Wil |
Thanks Will.
Re: Factory Ride Height
Ronin..
No they are not thus the cause of the bump steer. Thanks, |
What are your reasons for not fitting the bump steer kit...best mod I ever did.
Measure from the driveway up through the center of the wheel to where it touches the lip of the arch.
What is your current height? What are your current tire & wheel sizes? |
Current ride height: Front is 26" and the Rear is 25"
Tires: 205x55x16 Front 225x50x16 Rear Tire pressure is at 33 F, 36 R Thanks, |
kqw,
I like these cars when the rear lip is @ the ht of the rear wheel, and then the nose is just slightly pointing down (about 1 degree). Your rear tires are 24.9 " in dia, so I would go w/ Wil's suggestion, which is what I have on my car @ 25 1/2F, 25R. |
Thanks Paul..
If set at 25.5f and 25r, will that eliminate the bump steer? Thanks |
If you set your car correctly at euro height, you should have little or no bump steer. The fender to the floor measurement is quite inaccurate though, so maybe do a search on the board for the proper way to measure it. You can also easily check that your tie rods are level.
Eddie |
FYI, the term "bump steer" is often confused with "I feel more bumps when I steer". Not so. Real bump steer is the term for excessive toe change as the suspension travels through the jounce and rebound range (wheel goes up and down). The car handles poorly (or at least not optimally) if you have this condition. It's caused by excessive low (or high) ride height without adequate compensation to the geometry.
Sherwood |
Why do you have so much air in your front tires? That can't be helping the ride. You have stock tire sizes, use stock pressure on the street. 29F/34R. (Look at the sticker in your door jam). :cool: |
Two things:
It should be a simple enough matter to re-adjust the front height. The screw is vertically mounted on the rear-most suspension pivot of the front suspension.....one full turn counter-clockwise ( worm's eye view) will lower the car 1/4". As you lower, toe will, I believe, get more positive....but for the amount you're adjusting, might not need to be readjusted. At Euro ride height, you won't need bump steer rack spacers. They are only 12-13 mm thick, so if you lower by 12-13mm, that's all these are good for. most people , when they lower, go down more than that and theoretically would require fatter rack spacers...but they don't fit. I was corrected by Chuck Mooreland that the tie rods being parallel to the ground is not the target.....it's being parallel to the lower control arm. Most of us ( me!) got confused over this because the lower control arm often is set parallel to ground, therefore a target of the tie-rods being parallel to ground seems proper...but for the wrong reason. Upshot? If your lower A-arm is slightly "down" towad the ball joint...better if you set the tie rod to same angle....but then not parallel to ground. Finally, NEVER set the lower control arm so that the inboard pivot point is lower than the outboard ( balljoint end) pivot point....if so you've gone too low... I guess that's more than two things....:( Wil |
Thanks Dennis...
Re: tire pressure; I haven't run 29psi in front tires since 1987 when the car had Dunlop D40M2's. But I thank you for the concern. My sticker in the engine compartment says 29F, 36R. Are you sure your's says 34R? All I want is the car to run like it did BEFORE the alignment. Will: thanks for the advice on lowering. |
Let us know how the car feels @ the new height.
Paul, will do....
Thanks again folks..... |
| All times are GMT -8. The time now is 06:23 AM. |
