hkspwrsche's Avatar
2 distributor vacuum hoses-help?
There are 2 vacuum hoses on the 81 SC3.0 distributor-
Looks like the one facing the fan shroud is plugged in where I can see it and the hose facing the left side cylinder bank is on the back of the throttle housing. Is this backwards??
thanks,
Harold
Old 10-23-2004, 01:02 PM
hkspwrsche's Avatar
Does any one have a good vacuum diagram? It could be all the hoses are mixed up. Hard to tell from the sticker on the car but, the distributer hoses definitely look off.
Harold
Old 10-23-2004, 01:09 PM
hkspwrsche's Avatar
I swapped them and the idle speed went up quite a bit but it had no power if this helps. It seemed to run fine while cold though with them switched but warm it almost seemed to be way advanced..?
Harold
Old 10-23-2004, 02:04 PM
Original Owner
tsuter's Avatar
Our host.... PP Parts has the drawings.... look here...
http://www.pelicanparts.com/911/911_Parts/1978-83/1-7-3.JPG
tsuter
78 911SC Turbo Targa
Thaaaats Right!!
Old 10-23-2004, 02:21 PM
Somewhere in the Midwest
MotoSook's Avatar
You owe me now Harold
Old 10-23-2004, 02:44 PM
hkspwrsche's Avatar
Thanks bud..I didnt find them under a search and didnt look far enough in the catalog.
Thanks to you also souk- I didnt see the pic show up for some reason, though.
Harold
Old 10-23-2004, 02:52 PM
ausgezeichnet's Avatar
Tsuter,
Where did you find that drawing? I'm looking for ther same one for a 84 Carrera 3.2L Thanks.
Mike
'84 911 Carrera Coupe (totaled)
'83 911 SC Coupe
‘06 Aston Martin Vantage V8
Old 10-23-2004, 04:05 PM
MotoSook's Avatar
for some reason Wayne's server won't link the picture, but go here:
See the vacuum section
http://members.rennlist.com/jimwms/CIS/CIShome.html
Old 10-23-2004, 06:38 PM
