-   -   Help - ident CIS tubes on 3.0 (http://forums.pelicanparts.com/porsche-911-technical-forum/181667-help-ident-cis-tubes-3-0-a.html)
ecm911 09-08-2004 12:40 PM
Can anyone identify any of the below:
1.Larger vacumn hose
2. Rubber hose attcahe to CIS box
3. Smaller vacumn hose attached to air box.
Also, the smog pump was removed from this engine, prior to my involvment.
I believe # 2and 3 should be attched to the smog pump, but not sure.
# 1 ???
I assume if I am correct and they related to the smog pump that they should simply be plug up. If not please let me know what to with them.
TIA
Earlhttp://forums.pelicanparts.com/uploa...1094672448.jpg
ecm911 09-08-2004 12:43 PM
try this picture
sorry, new at this digital picture stuff. Hopefully this has my annotations. Earlhttp://forums.pelicanparts.com/uploa...1094672597.jpg
ecm911 09-08-2004 12:48 PM
sorry, you can't read the numbers,
# 1- left hand circle
# 2 - center
# 3 - right hand circle
thanks
Earl
Paulporsche 09-08-2004 01:17 PM
Earl,
If you search the exploded views in the tech section, you will find a routing diagram for everything. There are two, so look for the one w/ the same decelvalve as yours.
