Clutch pedal feels 'jittery' after warmup.
My clutch pedal feels firm when the car starts and through casual driving, but when I shift more often the pedal starts to feel has bumpy/jittery/unsmooth. I always push the pedal to the floor and the car shifts normally. Any ideas?
'90 C2 62K; resealed and updated. |
My exact problem...except I have an 83 SC!! Hope we can find some answers.
Steve Ware 83 SC Euro Cab Newberg, Oregon |
Usually, the "jittery" feelings are from contamination of the clutch, often oil or fluid of some kind. Someone else will have to address the warm vs. cold problem though....
Not much help -Chris
1987 Guards Red Targa (sold) 2006 Toyota Tundra DC 4x4, the "man-e-van" 1998 CR500 Well on the fringe...... |
Certified Pre-Owned
Clutch is gone...
'84 Carrera Coupe |
TO bearing?
If the clutch pedal is vibrating when not engaged, the throwout bearing is shot.
Pete Brown '87 911 Coupe '20 718 GT4 '25 Aviator '25 Mach E |
Is it bumpy while depressing the pedal and releasing?
I had this problem and it was a bad clutch cable, which had worn into/through the telflon casing. I believe that was caused by not keeping the cable adjusted properly, allowing constant tension on the cable and the eventual wear. The cable was catching/binding on the casing.
Tim 83SC Coupe |
I have a hydraulic clutch mechanism, not a cable system. The engine was resealed (including new rings, head and base cyl. gaskets, …) in January this year. The clutch plates and flywheel weren’t replaced this time, but the release fork, shaft and release bearing were replaced.
The problem is not constant. It comes and goes. It has a funny feeling as if a pump assist isn’t working correctly or like when anti-lock brakes take control. It seems to occur most often when I shift frequently over 15-20 minutes. I didn’t feel it at all today.
Everything seems fine. I probably was imagining it happening.
Designer King
Check the clutch release lever or auxiliary spring bushings.
BTW do either of you guys have the infamous exploding rubber center clutch?
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
