-   -   Erratic Voltage ? (http://forums.pelicanparts.com/porsche-911-technical-forum/181852-erratic-voltage.html)
WydRyd 09-14-2004 07:15 PM
JoeA, those things can run 18-24 volts when they go real bad and they'll blow the ECU or draw way too much current from the injectors and blow out the injector driver internally.
Just a warning for others, that's all.
Early_S_Man 09-14-2004 07:25 PM
One of the critical items in the electrical system that can be blown in an instant with spikes above 18.0 Volts is the factory alarm module!
WydRyd 09-14-2004 07:31 PM
Agree Warren, but not as critical as a DME or Injector driver! Aaaarrrgghhhh!!! :eek: :mad: :confused:
Joeaksa 09-14-2004 09:43 PM
You guys are giving me the shakes just thinking of a alternator going this far above its normal rated voltage! I have done a "smoke test" too often with my Brit vehicles and really like a nice stable voltage source!
Joe
WydRyd 09-14-2004 09:52 PM
Hehe, well, you are one lucky bugga that yours survived that long at 16v or so... really playing with fire there. All it takes is the Alt or VR to send a Vspike in the danger zone and you'd be looking at a depressing repair bill :(
My alternator is totally screwed too (bearings are totally worn), but luckily it was under-charging/supplying under load. I cringe at the thought of it going the other way :eek:
