WydRyd's Avatar
JoeA, those things can run 18-24 volts when they go real bad and they'll blow the ECU or draw way too much current from the injectors and blow out the injector driver internally.
Just a warning for others, that's all.
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 09-14-2004, 06:15 PM
Early_S_Man's Avatar
Porsche Crest
One of the critical items in the electrical system that can be blown in an instant with spikes above 18.0 Volts is the factory alarm module!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 09-14-2004, 06:25 PM
WydRyd's Avatar
Agree Warren, but not as critical as a DME or Injector driver! Aaaarrrgghhhh!!!
Merv
'89 911 Turbo Cab
Old 09-14-2004, 06:31 PM
Senior Member
You guys are giving me the shakes just thinking of a alternator going this far above its normal rated voltage! I have done a "smoke test" too often with my Brit vehicles and really like a nice stable voltage source!
Joe
Old 09-14-2004, 08:43 PM
WydRyd's Avatar
Hehe, well, you are one lucky bugga that yours survived that long at 16v or so... really playing with fire there. All it takes is the Alt or VR to send a Vspike in the danger zone and you'd be looking at a depressing repair bill
My alternator is totally screwed too (bearings are totally worn), but luckily it was under-charging/supplying under load. I cringe at the thought of it going the other way
Merv
'89 911 Turbo Cab
Old 09-14-2004, 08:52 PM
