-   -   starting problem (http://forums.pelicanparts.com/porsche-911-technical-forum/181869-starting-problem.html)
zoobsvt 09-09-2004 05:32 PM
starting problem
when the car is cold it turns right over, after being driven and bringing the car to temp, if parked for more than ten minutes the car has problems starting the engine will crank but will take about 15 cranks to turn ove, any ideas? 79sc
LakeCleElum 09-09-2004 05:40 PM
Check valve in your fuel pump or your accumulator....
Paulporsche 09-09-2004 05:41 PM
Search hot start problems. It's usually the fuel accumulator or fuel pump check valve.
filou 09-10-2004 06:55 PM
o
