sport exhaust - can I short the exhaust pipes?
Hey Guys,
I have a 911T 2.2 with sport exhaust . Wondering if its possible, and if anyone has shortened the exhaust pipes. They are very long. Any changes in performance/sound with shortening? Any comments or suggestions? Thanks Andy 81 911SC 70 911T
I would rather be driving
OK what color is that? I like it. So bright and vibrant.
Yes you can shorten them. It will change the tone a bit. Some people have used 5". There was a thread on this a while ago. Try to search for "cut* OR trim AND sport muffler"
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
If you do shorten consider using a chain based pipe cutter. It will leave a very nice, clean cut that can be finished easily. Most garages use them.
![]() http://www.etoolcart.com/browseproducts/Exhaust-Pipe-Cutter-KD2031.html
Warren & Ron, may you rest in Peace. |
Formerly bb80sc
Yes you can. I cut 8" off my pipes and finished them off with some chrome pipe covers. I did not notice a whole lot of change in sound. Nice color!
Cheers -Brad 2015 Cayman GTS 2015 4Runner Limited |
Andy,
Just wacked 6 inches off of my tips. At idle it will sound a bit deeper/throatier. I found a pipe cutter at Lowes that adjusted to 2 1/8 inch max. Pipe is 2 inches. Took about 10 minutes. Good luck,
Tom IG@tomkearns '94 WTL 964 |
