ecm911's Avatar
Hard fuel lines installation ?
Does any body know how to secure the hard fuels on a 911 SC?
I am in the process of restore the fuel lines in my project. I order evry part from the PET. It only states one clip to secure the rear hard lines. Doesn't seem right. Any help would be greatly apprectiated. Picture would be wonderful.
I can't seem to find any resource on thus. They can't just hang there??
TIA
Earl
Old 09-11-2004, 06:15 PM
Britain Smith's Avatar
Are you talking about the lines that run through the center tunnel? I am going to have to put new lines in my car also...can you share on the details of your projects? What parts have you been able to find from Porsche?
-Britain
'69 912 w/ 2.3L Type-4 Turbo Engine
'74 914 1825lbs, JDM Subaru STi Spec-C Engine, Lotus Suspension, 930 Trans.
'80 924 AAN 5-Cyl, Corvette C5 Transaxle - Team UBoot Rennwerks
-- www.britainracing.com --
Old 09-11-2004, 07:01 PM
ecm911's Avatar
Britian -
I have replaced the lines through the tunnel. Here is a thread that I found very helpful. Replacing pressurized fuel line from pump on 78 SC?
( search for "replacing pressurized fuel line")
There is a great post from David that includes part numbers. Raed this before you do anything, it was very helpful to me.
If you can get a PET it has all of the part numbers and diagram.
If you can get access send me an email and I will print it out for your car ( need yr etc) and send you a copy. FYI- pelican parts has the diagram but not refer to part #'s. I was able to get all parts from pelican and Porsche( where pelican did not have).
FYI- you will need an assistant running the lines and the installation damn rubber grommets at the end of each tunnel will test your finger strenght - I still can't move my one thumb!!
But overall it was not a difficult task.
Currently I am trying to figure out the "hard" lines - the ones in the rear of the car - that run form the Tunnel to the engines. I have them installed but not secured to the car. Since my project car did not have fuels when I purchased it , I am running sort of blind - no reference as to what the final product should look like.
Starting to get frustrated.
If your lines are still in the car how are the secured to the body?
A picture would be abosultely wonderful.
I have to go now, my wife is give me the rush. If i can help in anyway let me know. I will check the board tommorrow.
Earl
Old 09-12-2004, 05:55 AM
