-   -   Setting CO help needed (http://forums.pelicanparts.com/porsche-911-technical-forum/182062-setting-co-help-needed.html)
Sameer 09-10-2004 10:25 PM
Hi guys,
How do you'll guys check your CO reading? From which tailpipe? If I were to set my CO at let say 3.5% with the probe/sensor in the left tailpipe and than when I put the sensor in the right tail pipe, it gives a lower reading. I guess this is because the right hand side of the exhaust is longer. So how do I set the CO? Isit from the left or right tailpipe?
