erratic idle 88 carerra
This only happens when I first start the car and then goes away once i get moving. The rpm's go from 800 to 1200 then settle at 800. I've recently replaced the idle valve. coulf warm weather be a cause?
Old 09-12-2004, 12:13 PM
I think this 'surge' is common to a few guys here.
Try a search.
Mine did it when I first got her, but since new plugs cap, rotor and
Steve W chip, it doesn't do it anymore.
I don't think those things fixed it though. I bought my car in November last year. Therefore when the weather gets cold again, who knows, the surging idle when the engine is cold may return?
ps. I did also get the idle and CO adjusted. I feel as though these two things may have been the fix. Sorry I can't be of more specific help.
"Understeer is the sign of the Devil"
1989 911 Carrera Targa (Black)
2001 Jaguar XKR (Silver)
Old 09-12-2004, 12:19 PM
Might try testing (ohm's test) your head temperature sensor...a faulty one can certainly create an eratic idle problem and is a fairly common "problem area" on these cars.
Marc Morrison
1964 356C coupe
'89 911 coupe
2008 Honda Accord
2008 Ford Ranger
Old 09-12-2004, 04:26 PM
Might try testing (ohm's test) your cylinder head temperature sensor...a faulty one can certainly create an eratic idle problem and is a fairly common "problem area" on these cars.
Marc Morrison
1964 356C coupe
'89 911 coupe
2008 Honda Accord
2008 Ford Ranger
Old 09-12-2004, 04:27 PM
