Oil Leak on 79 Sc
I have a slight oil leak on the front passenger side of my engine. Most noticable after driving. Oil smoke when the engine is shut off. I assume this is dripping on the heat exchanger. Would this be the oil return line fitting or something more sinister.
What freekin Oil Leak?
It could be from a couple of places, but probably nothing sinister. You may want to refer the Pelican Techncial Info section:
http://www.pelicanparts.com/techarticles/911_oil_leaks/911_oil_leaks.htm
Steve '79 930 US |
Hee hee TurboBert: What Oil Leak?
356Six, I'd get under the car and have a look. If it is a bit oily under there give it a clean with a degreaser to make it easier. Err, us guys with SCs don't mind a bit of oil leaking now and then. |
Good suggestion - degreaser first. I don't know if I can afford anymore oil drops. My yard is going to be classified a hazardous waste site with a harley and to p-cars marking their territory.
73 914-6, Vintage Spyder,05 997(sold), 04 Anniversary 911 #151(sold) 08 Beck Speedster #317 (sold) 76 911S (sold) 76 911 Targa (cut up & sold) 86 951 (sold)914-6 (sold) |
Syracuse, wow, I didn't notice before. What an interesting bit of the country. I love all those places from Buffalow to NYC. I did a trip through those towns years ago and had a great time. And so much modern history around that area, origional Edison. GM, IBM...
leaker
If it's like mine, the couple of drops mine would drop after a drive all but stopped when I used the car more....
Paul
Paul '87 Carrera cab; '19 Ford Flex for the Dane and Lab; '17 Tacoma for truck stuff. '96 993 cab (gone, oops); '82 SC (gone) |
If it's like most of our cars, it's nothing sinister. Check valve cover gaskets and oil return tubes. It's not unusual for mine to have a small oil puddle after letting them sit for awhile.
Designer King
Bill,
And don't forget Kodak, Xerox, Bausch & Lomb, French's, Carrier, Corning Glass, Watkins Glen, lots of wineries, and about half a dozen Frank Lloyd Wright houses...
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
