bumper pad swap?
what's involved in a bumper pad swap? I assume I've got to pull either the bumper or the exhaust? Can't seem to reach the nuts as is...
Yes, I did a search, but didn't pull anything up. |
You need to pull the exhaust to get at them. I removed them when I had my engine out and really don't recall seeing a way to get at them with the exhuast in place.
Me like track days
Whatcha swapping? Big for small, or just a replacement?
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
Formerly bb80sc
Todd, leave them off!! You know how much those suckers weigh and how that is multiplied at speed thru turn 9 at Willow
Cheers -Brad 2015 Cayman GTS 2015 4Runner Limited |
my mechanic just removed them and he didn't touch the exhaust so there is a way to do it but I can't tell you how. Let me ask my mechanic tomorow how to do it.
X/A |
big to small...I want to keep something back there for daily street adventures.
When going from big to small, are there any holes to fill in the bumper? Or is it a straight swap?
mike 86 coupe
Mike '86 911 coupe '85 BMW 535i '11 Cayenne |
yes, there are holes to fill. I'm pretty sure you can get plugs for them though.
Montana 911
Todd you can reach them without taking off the exhaust, I did...but I wasn't ready to paint my rear bumper at the time so I put them back on.
H.D. Smith 2009 997.2 S 3.8 PDK 2019 Ford Ranger Lariat FX4 Baby Raptor 2019 Can Am Renegade 1000R XC 2020 Yamaha YFZ450R |
Todd I call my mechanic and he told me that you need to remove the bumper extensions
good luck!
X/A |
The rear bumper is pretty easy to remove, really. You'll probably want the bumper off to get the wires re-routed to the license plate, anyway, so you may as well pull it. It sounds like a lot nastier job than it really is -- once I sat down and did mine, it only took about 30 minutes.
Dan
'86 911 (RIP March '05) '17 Subaru CrossTrek '99 911 (Adopt an unloved 996 from your local shelter today!) |
19 years and 17k posts...
I removed my valence and was able to easily get at the bumper and pad bolts to remove them...
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
What are you guy's talking about??? This is one of the easiest things to do. You DO NOT have to remove the exhaust; just the heat shield. A few 15mm nuts and they are off. As far as the wiring goes; just remove the light housing from the bumper pad and disconnect. 30 minutes at the most.
1986 3.2 Carrera |
I just removed mine without removing the bumper, but I scraped the S**T out of my arm on the valence. I am removing my bumper next to refinish it. I found 3/8 inch plugs at the auto store to fit the holes, but although there are only 3 bumper pad bolts, there are 5 (or so) holes each side! I bought the lite-n-bolts to illuminate the plate, so I will need to drill holes behind the plate to wire those. Any suggestions on permanently filling the holes. I would weld them shut and grind it down, but its Aluminum!!!. Bondo, JB Weld, anyone? I really don't know how to deal with aluminum.
Doug
Doug 79 SC Targa w/ ITBs, 2004 Cayenne Turbo |
Friend of Warren
You can use JB weld, but give it a good 2 days to cure as it will shrink a bit. Then use a bit of filler to finish it off and paint!
Kurt V No more Porsches, but a revolving number of motorcycles. |
Thanks Kurt. I will give that a try. I have not used JB before. I suppose I will grind / sand off the corrosion spots around the holes, JB them full, and skim coat some Bondo to sand to a smooth finish.
Doug
