copper's Avatar
Heat Exchanger hole
1969 911T
I have a small hole in my right heat exchanger from something hitting it. It is about the size of a dime.
What can this cause?
What are recommended fixes?
My local guy has recommended a high heat epoxy to patch the hole.
Jim
Jim Dean LL.B. - London, Ont, Canada.
1969 911T "Blood Orange" Euro (Brought over from Germany in 86)
Engine and brake system rebuilds 2006 & 2007
"Oversteer scares passengers, understeer scares drivers."
Old 09-12-2004, 10:11 PM
JNadal's Avatar
Carbon monoxide will enter the cabin if it isnt fixed
Have a small piece of metal welded in
Old 09-13-2004, 11:11 AM
MAGA
Tim Hancock's Avatar
If it is in the heat exchanger outer sheet metal (not the exhaust tube)then it I doubt you would ever notice a difference in the heated air temp or flow so leave it be. An easy fix for this if you do not weld, would be a pop riveted steel patch.
On the other hand, if it is in the exhaust tubing and is leaking into the heat exchanger sheet metal then you need to fix by welding so that you do not get fumes into the cabin.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne
0% Liberal
Men do not quit playing because they get old.... They get old because they quit playing.
Old 09-13-2004, 11:48 AM
copper's Avatar
The hole is in the bottom of the heat exchanger, just in front of the muffler. Pretty much at the back end of the unit. Looking at the surface, there are several round pieces in it which are about the size of a quarter and appear to be brace ends or something.
One of these has been hit from below and has shifted, leaving a small opening into the exchanger.
And yes, I do smell fumes in the cabin. That's why my windows are always down...
Jim
Old 09-13-2004, 03:04 PM
RETIRED
Joe Bob's Avatar
Kevorkian heat exchangers....fix it before you get CO poisoning....
2012 ML350 3.0 Turbo Diesel
Old 09-13-2004, 03:14 PM
Randy Webb's Avatar
Sounds serious. I'd contact John Daniels (Mr. SSI) and ask if they can repair, or should you replace, or can it be reparied by a welder where you live w/o removal. See if he can look at a photo.
Old 09-13-2004, 04:54 PM
copper's Avatar
Thanks for the input.
It would seem that it's been like that for the past 16 years or so...
Ever since we first bought the car.
It's been in storage for the last 10 years and now I found it going over it in detail. The right side heater hose which leads from the engine air output to the heat exchanger was removed intentionally. The hole in the exchanger and resulting opening to the exhaust would explain why this was done.
At any rate, I'm going to take it in to my local mechanic and see how bad it is and whether it can be welded shut for a good seal.
Thanks for the advice to all.
I am learning fast.
I changed my plugs today and fell victim to the dreaded "lost socket" when it came off the extension and sat inside. But fortunately, there was plenty of info available here from past experiences and I had no problems recovering and finishing the other 5 without a hitch.
Jim
Old 09-13-2004, 06:58 PM
RETIRED
Joe Bob's Avatar
Use the supplied spark plug wrench in the tool kit.....
Old 09-13-2004, 06:59 PM
copper's Avatar
I'd love to, but the original tool kit is no longer in existence after 35 years...
Jim
Old 09-13-2004, 11:42 PM
Senior Member
Jim,
How about a picture of the hole? Would tell a lot about where it is and the proper repair.
JoeA
Old 09-14-2004, 06:06 AM
