-   -   Wayne's 101 Projects Book (http://forums.pelicanparts.com/porsche-911-technical-forum/182490-waynes-101-projects-book.html)
DavidI 09-13-2004 08:59 PM
Today I had a free day and decided to tackle another of the projects from Wayne's book. I adjusted the parking brake guided by a master MIT mind. It got me thinking, how many projects have I and Wayne done together?
Projects by number in Wayne's book:
1. jacking up my car
2. changing the oil
4. air filter replacement
5. fuel accumulator
6. washing my car
9. clutch cable replacement
10. helper spring replacement
11. clutch adjustment
32. pop-off valve onstall
36. transmission oil change (Swepco)
37. shifting coupler replacement (on my old 912)
40. pedal cluster rebuild
46. brake pad replcement (912)
47. rotor replacement (912)
49. brake bleed
50. parking brake adjustment
53. brake caliper rebuild (912)
55. lower front end
79. lens replacement (912)
71. H4 upgrade (912)
73. hood crest install (912)
77. weatherstripping replacement (912)
78. window regulator replacement (912)
79. glass removal (912)
81. hood shock replacement (912 and 911)
86. fuel sender replacement (912)
90. oil gauge and sender replacement
93. install new stereo
99. using a porsche bra (912)
100. polishing alloys
Does anyone have me beat?
:D :D
David SCWDP
aigel 09-13-2004 11:01 PM
I got about 50 the last time I counted. And that's with a bunch of stuff being redundant or not applicable to the SC.
G
Schrup 09-13-2004 11:19 PM
Wish I could find mine, I seem to have lost it when I moved. I will probable order another one with my next order, it breaks things down in a more simple way than the Bentley & the pics come in handy.
Wayne 962 09-14-2004 12:26 AM
I've got you all beat!
-Wayne
Paul Franssen 09-14-2004 02:22 AM
In that case, Wayne, you got to show your hand! :D
Schrup 09-18-2004 08:30 AM
Woo Hoo, found my book yesterday while visiting my mother-in-law. Last winter I used her garage to work on my car & it was in a pile of magazines on her coffee table shelf. What a relief, there are so many useful pics in there that will come in handy when I reassemble my car.
Paulporsche 09-18-2004 08:34 AM
David,
Sounds like you got your money's worth out of that book.
sammyg2 09-18-2004 08:57 AM
I'm up to 102. (first liar don't stand a chance around here ) ;)
red-beard 09-18-2004 09:14 AM
Well, I bought the car and have done several projects on it, so I _started_ at 101....
Sonic dB 09-18-2004 10:04 AM
I used the book recently to do the clutch helper spring. It was a bit frustrating because the book appears to have a reverse-image photo where the helper spring shows up on the opposite side of the picture, than it is in reality. Trying to orientate that thing correctly was a ***** and eventually I just figured it out myself.
Wayne 962 09-18-2004 11:45 AM
It is a confusing shot because the angle is weird under the car. It's not a reverse image though - check the transmission numbers, they are not reversed characters...
-Wayne
azasadny 09-18-2004 07:26 PM
David,
That's quite an accomplishment. I think in the 2 years I've had my car I've done about 35 projects...
Sonic dB 09-18-2004 07:51 PM
Yeah you are right. It looked funny when trying to analyze it flat on my back lying under the car.
It reminded me of the time I saw a pic of Paul McCartney playing a right handed Hoffner Bass.
84porsche 09-18-2004 08:20 PM
I have the worst record for your book Wayne.
6. washing my car
37. shifting coupler replacement - won't attempt again until I know alot more - the last time I drove the car home in 1st gear.
DavidI 09-19-2004 02:05 PM
I love that these cars can be worked on by DIY'ers. The book is excellent.
Wayne 962 09-20-2004 05:52 AM
Precisely the point - thanks guys!
-Wayne
