easy "A" arm bushing removal
Easy method of removing old vulcanized bushings from "A" arms to replace with poly/graphite bushings. Pictures are shadowy but used come along between two heavy objects
'68 911 2.2 "E" PMO Carbs, Electromotive Crankfire Ignition, Adjustable Spring Plates, turbo tie rods, Bilsteins, headers, MB911 muffler... "The sea merely lies in wait for the innocent but it stalks the unwary." |
Banned
you gotta be kidding right? i just heated them a bit and they came off pretty easy. plus i dont have any abandoned heavy machinary around to hook it to.
wait till you get to the rears, thats where the fun begins.... |
you got all that stuff...but no fire?
big AL '77 911 |
I would rather be driving
Rears are easy too. Heat the inside until they sizzle. twist off. Takes about 2 min each side with the OA torch.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Well, I, er, uh....no.
Here is another method that requires a little less hardware. Heat the metal for a couple minutes to soften the rubber. The mounts then twist off easily. No drama. Brute force methods without heat are very likely to tear or otherwise damage the metal of the mounts. A little heat makes all the difference.
Chuck Moreland - elephantracing.com - vonnen.com |
WTF? That reminds me of the poor soul who couldn't get his rear t-bars out. He had comealongs hooked up to trucks and phone poles wiht the car inbetween
![]() ![]() You're not, by chance, the same guy, are you? ![]() ![]() |
never ending projects
tough crowd
Hey billyboy -- nice shop!
Actually, I think I'd like Billy's shop setup. I need to get a little ROOM around me. I'm like the guy that has a lift, but has too many cars, so there's already a car on the lift and he's on the ground crawling under another parked below.
![]() I'd love to get the hell out of the Getto by the Sea and be up in Atascadero except in August when it's 150 degrees. |
personally, i would use two cows.
Driving member
Sorry I just have to say that it seems a little like driving 4 penny finish nails with a 12lb sledge hammer.
But hey what everever works for ya ![]()
Jerry '86 coupe gone but not forgotten Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason. |
screwed up a arm bushing removal
Gosh, I fell terrible now for doing it that way. I was told that it was a going to be a major ordeal of sawing, cutting and burning rubber so I just thought this would be a slick way with no stinky fumes.Next time I'll ask the board for the advice before hand. Some of those remarks made me feel like I just got bent over in the shower to pick up the soap.
Billy, we're just having a little fun with you
![]() But seriously, I've done this more than a few times. I learned the hard way what brute force methods can do to the mounts. You've got yours done, so comments from us armchair QBs aren't helping you. But others will read this and it will be helpful to them to learn the tried and proven techniques.
"Gosh, I feel terrible now for doing it that way."
- You owe us all a beer! Seriously -- It worked didn't it? Check for distortion in the A-arms, then reinstall. |
I love creative engineering.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
