KCPSG's Avatar
oil sending unit update
I don't know if you remember this thread, I have been offshore (@ work) a long time but I did finally get to the bottom of the oil pressure problem.
It turns out that it WAS the oil sender. it said 0 - 10 bar on the old sender, so my gauge was only reading 1/2 of what the actual pressure was. I have a new sender and WOW what a difference!!!
It actually reads like its supposed to! 1 BAR per thousand RPM ...and a little more
2 questions about temp and clutch
I also put in the new oil cam restrictor adapters, and what I noticed more than anything is (other than more pressure) is that the engine seems to run cooler than before. Has anyone else made this change and noticed the same thing?
Phil
2005 GT3 Milltek Exhaust/ECU reflashed/OEM Short shift
1988 911 coupe (GP white) Turbocharged
1998 BMW 328i
Old 09-15-2004, 08:13 PM
