Me like track days
Craig 930 RS's Avatar
Question ~ WEVO - lineup, availability, pricing? ~
Ok, we've seen the tempting goods from WEVO - let's hear what all the products are and when they are available - and a bit more on pricing would be cool -
$ in hand, ready
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 09-15-2004, 09:21 PM
petevb's Avatar
You must mean info beyond what's available on the web site, yes?
http://www.wevo.com/porscheproducts.htm
69 w 997 GT3 3.6L
Old 09-15-2004, 10:08 PM
concentric's Avatar
I called about the brake sets...
Mucho dinero if they go into production.
The super nice motor mounts are $150/pair. I bought some at GAF.
JCM
Stuff of marginal consequence:
- 1974 911"Carerra" sunroof coupe
Old 09-15-2004, 10:12 PM
Me like track days
Yes - the brakes, engine bar, engine mounts - all the new goods -
Me like track days
WEVOID..........you out there?
Old 09-16-2004, 10:19 AM
OCD project capitan
BigD9146gt's Avatar
What level of braking are you wanting to go too? Would Boxster calipers be enough?
I saw Wevo's billit rear caliper at the show, very nice stuff. Get ready to watch the $ in hand fly fly away (for a good cause of course).
Don Welch
'73 914ish ->6ish GTish 2.8 twin plug mfi... happy camper.
Old 09-16-2004, 10:36 AM
OK Trendsetters,
This is as much as I can tell you, any more would be making stuff up.....
At the GAF we had all our standards on display. There were 3 new items that had not been seen before - unless you had managed to sneak past Ruby at the front door....(unlikely!)
The WEVO SS Engine Mount is a new release product that is now available for $79.85 each, these are available through Pelican.
These were displayed at GAF - not very well, on a stand that included a gold zinc plated engine mount console and lightened cross beam, those were an unplanned distraction, not products, we should have powercoated them black instead.
The WEVO Spring Plate System (WEVO SPS) is a complete upgrade for the rear suspension of torsion bar 911's.
Replaces the stock spring plate with an easy ride height adjustable version that features a snubbing screw to avoid un-noticed rotation of the ride height set screw that can occur with other designs. The rubber bushes that carry the spring plate are replaced with a large, sealed ball bearing and a large needle roller bearing - also captured behind a seal. When installed with a "monoball kit" for the inner pick-up this design results in a virtually friction free assembly. The system eliminates traction robbing stiction from the rear trailing arm motion, allows for easier corner weight set-up and actually provides a smoother ride than some of the other performance oriented bearing solutions.
This product is planned for release, although not currently available.
This kit is production ready, undergoing the final stages of testing and is intended to be available in the Pelican catalogue by Christmas time. The projected retail price for the 2 assemblies (one car set) is about $900
The WEVO 911 Spec Brake Kit, was also on display. This is an investigation by Windrush to satisfy a complex brief to design a brake package peculiar to the mounting and packaging challenges of the 911 suspension and Fuchs wheel design.
This was displayed to gauge interest from retail and trade customers and to showcase our Design, Engineering and Manufacturing prowess.
We have not made a decision to manufacture this product - however, we will complete the essential and complex testing of the product to ensure that it does meet the final aspects of the design brief.
If this kit reaches production, the workings show a probable retail price of $4400.
This kit is unique in the fact that is bolts 930 size brake pads and rotors directly to a normally aspirated 911, 1969 through 1989, it use no adapters, no wheel spacers and fits under 15 x 6" wheels - it requires no additional parts beyond those included in the kit - with the exception of a 23mm Mastercylinder to suit your chassis vintage and a car set of brake pads.
This kit is not available - although we are gauging interest, so please feedback your thoughts.
Perhaps the threat of a product like this will push Brembo or another big manufacturer to resolve a similarly elegant and truly complete package.
If we do elect to manufacture this kit, it will certainly enjoy a launch to Pelicanites through this forum.
I think this cover's all the unexplained?
Regards
Hayden
Old 09-16-2004, 12:52 PM
RallyJon's Avatar
Subtracting out the cost of rotors, that's seems like a very high price for reworking an archaic caliper design. Why not start with a clean sheet of paper or one of the many modern calipers from AP, Alcon, Brembo, PF etc? Superb brakes for 15" wheels are available from every manufacturer given that all gravel rally cars use 15" wheels. Adapting them to fit Fuchs shouldn't be too hard with that budget.
993 · 911 · STI · S4 · rally car
Old 09-16-2004, 01:13 PM
RallyJon,
The subtlety of our solution is obviously not apparent, this is a clean sheet, we had the option of using all the calipers you listed, in every case the necessary compromises violated the brief.
We have incorperated a multitude of features from modern calipers and packaged them into a "period obvious" geometry suited to the old fashion wheel / hub design of the pre 1989 911's.
One reason you dont see a kit available and people like Steve Weiner is so busy converting 930 calipers is that the modern alternatives, whilst superb, are not complaint with packaging constraints.
We would have been happy to do as you say, allowing more profit potential for certain, but we elected to conduct the project in the way we did and are yet to decide whether to continue.
$4400 is well within range of other kits that cost something in the high $3K region, yet require alternate wheels, tires, etc, etc.
Thanks for the feedback, it is feedback that helps shape the nature of the explanation and description of the specifications.
Regards
Hayden
Old 09-16-2004, 01:28 PM
Az911's Avatar
Send a message via AIM to Az911
Hayden can you post a pic of the engine mounts?
72T RS look
96 993
Old 09-16-2004, 01:52 PM
