DIY Reproduction Window Maroney Sticker
I was looking to re-create a window sticker for an 84 Targa. I decided to make a template out of power point. Currently its only 8x11.
It needs some tweaking but its mostly all there from what I could gather. https://1drv.ms/p/s!AtY3KJaAFavh5DsVjyDbHIr-g_lv?e=TfNe2h Once opened things will align as per the sticker sheet, if they don't you can move them around easily. |
Rescuer of old cars
Basic layout looks OK, but most of the fonts are wrong.
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
Thanks for a screen of a real sticker. I've seen some with the blue and others with underlining on the EPA stuff. If anyone knows of what is a close font I can change it. I have no idea. Some were using some dot matrix font but that wasn't right either.
Full Send Society
Porsche:
https://fontmeme.com/porsche-font/#:~:text=Porsche%20font%20here%20refers%20to,in%20 1931%20by%20Ferdinand%20Porsche.&text=Under%20the%20shield%20is%20the,the%20font%20 for%20free%20here. Audi: https://www.audi.com/ci/en/intro/basics/typography.html
-Julian 1977 911 S: Backdate, EFI/ITB, AC project in the works: http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html |
Back in the early 2000's when I was restoring a 914 there was a person in the Pelican 914 group who had the correct dot-matrix paper and some sort of dot-matrix printer and would make them for owners for like $50 or something. Was an older style than these but it was neat even back then to see the resourcefulness of this community!
Brian Miller - Scottsdale, AZ 1971 Porsche 911 T Targa @targatuesday :: 2005 Ducati Monster S2R :: 2008 Porsche Cayman S |
If you searched with the correct name "Monroney" sticker, then you may come up with a lot more information. Several people have done this before you, and some with good results.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s Addicted since 1975 |
I was able to build this one from what I saw here and rennlist. No one has a perfect template. So this is a hodge podge of what I found.
What I’m looking for now is the correct font for the printer. Or something close. I haven’t seen that yet. When you print this I lowered the contrast on the print font so it does print with dots a little. |
Cars and Cappuccino
Speaking of Barrier - Beck in Charlotte.... ![]()
http://www.carsandcappuccino.com 1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits 1985 Prussian Blau M491 Targa 1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe 1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday) |
