-   -   beru distributor cap fails (http://forums.pelicanparts.com/porsche-911-technical-forum/183089-beru-distributor-cap-fails.html)
jbrinkley 09-17-2004 06:43 AM
got a cap from vertex (beru) cause it was a couple $ cheaper.
It lasted all of 100 miles. the carbon tip came loose from the spring. There's a center burn mark also that could have been the cause or the result of the tip comming off
I guess long story short, get the bosch.
john walker's workshop 09-17-2004 07:13 AM
they tend to fall out un-noticed as the cap is turned over to install it. once in place, if it stayed in there, the rotor would keep it from going anywhere.
