Send a message via AIM to jstein
high pitched whine after re-wire / new alternator
Just replaced the alternator in my 1979 911SC - while I was working on the 'trecity, I decided to clean up some of the wiring mess that was left over after the PO replaced the fuel injection with webers.
Everything went smoothly - but (isn't there always a "but"?) when I put the ignition in 'run', I notice a high-pitch sound from the engine compartment that I don't think was there before. It's hard to identify where it's coming from, but I think it's from the CDI module.
I'm pretty sure it's _not_ the fuel pump (I'm familiar with that noise).
The car seems to be running fine - haven't taken it out on the road yet.
I do notice that the CDI module seems to get warm - is this normal?
The PO removed all the rear defogger relays/etc - so none of that is back there anymore.
any other ideas what could be the cause of this?
Old 09-18-2004, 02:05 PM
you're probably correct about the CD unit. bosch units whine. unplug it and see if it goes away.
206 637 4071
Old 09-18-2004, 02:23 PM
Unplugged CDI: no whine.
Plug it back in : whine-o-matic
Imminent failure, or normal operation?
Old 09-18-2004, 02:31 PM
Randy Webb's Avatar
Normal.
Good thing it wasn't your girlfriend.
Old 09-18-2004, 02:40 PM
